Dual set-up for my ‘51 8n
Goto page Previous  1, 2
michford
PostPosted: Wed Jan 13, 2021 6:24 am    Post subject: Re: Dual set-up for my 51 8n Reply to specific post Reply with quote
I'll get full dimensions of the spacer ring tonight. I think there would be a fair amount of disassembly work to be able to press out original rear axle studs and press in longer ones as not sure if longer studs could fit for install without a bit of axle shaft disassembly involving the locking collar. Not cheap, but much easier to stick with special extenders to use with spacer ring.
Kirk-NJ
PostPosted: Wed Jan 13, 2021 6:39 am    Post subject: Re: Dual set-up for my 51 8n Reply to specific post Reply with quote
Yep plate is 1 1/4" thick or maybe a hair longer
TheOldHokie
PostPosted: Wed Jan 13, 2021 8:43 am    Post subject: Re: Dual set-up for my 51 8n Reply to specific post Reply with quote
CVPost-Michford wrote:
(quoted from post at 10:24:46 01/13/21) I'll get full dimensions of the spacer ring tonight. I think there would be a fair amount of disassembly work to be able to press out original rear axle studs and press in longer ones as not sure if longer studs could fit for install without a bit of axle shaft disassembly involving the locking collar. Not cheap, but much easier to stick with special extenders to use with spacer ring.
Appreciate the dimensions. I suspect I can get the spacers made at a pretty reasonable cost and a pair will ship anywhere flat rate for $14. Work required to swap studs is part of what I want to investigate. I have to pull the axles on my 8N anyway Wink
Another thought was to use the OEM lugs and nuts to bolt the spacer to the hub and OTS male lug nuts to bolt the outer wheel to the spacer. That would require some machine work that i would like to avoid....
TOH
michford
PostPosted: Wed Jan 13, 2021 5:14 pm    Post subject: Re: Dual set-up for my 51 8n Reply to specific post Reply with quote
For TOH - Dimensions for 1156 dual wheel spacer:
7.88" O.D. x 1.50" thick
4.12" I.D.
(Cool 1.25" holes through on a 6.00" bolt circle
.06 x 45 degree chamfer O.D. & I.D.
Break edges of 1.25" holes
Was thicker than I thought, that will change your estimate.
michford
PostPosted: Wed Jan 13, 2021 5:27 pm    Post subject: Re: Dual set-up for my 51 8n Reply to specific post Reply with quote
Modern view show a smiley face instead of an 8 in parenthesis for the quantity of the 1.25" holes, not helpful.
TheOldHokie
PostPosted: Wed Jan 13, 2021 5:58 pm    Post subject: Re: Dual set-up for my 51 8n Reply to specific post Reply with quote
(quoted from post at 21:14:21 01/13/21) For TOH - Dimensions for 1156 dual wheel spacer:
4.12" I.D.
(Cool 1.25" holes through on 6 bolt circle
Thanks!!! Dam close to what i sketched up yesterday. Too thick for laser cutting. Maybe use two .750 spacers per wheel and weld them together. Probably 50% more cut time but material per piece is cheaper so should not be killer expensive. Ill run it through the online system tomorrow to get a ballpark number.
TOH
Tim PloughNman Daley
PostPosted: Thu Jan 14, 2021 6:34 am    Post subject: Re: Dual set-up for my 51 8n Reply to specific post Reply with quote
Ferguson used 9/16 bolt sizes
PostPosted: Thu Jan 14, 2021 6:41 am    Post subject: Re: Dual set-up for my ‘51 8n Reply to specific post Reply with quote
Are you the guy from Traverse City who bought my 8N spacers a few months ago? A guy from Utah, Jim Webb used to make them, may have some more on shelf he'd part with, and Steiners used to make them too and also may still have some NOS to get rid of. Anyone interested should contact them. The original poster asked about the 8N dualies.
Tim Daley(MI)
michford
PostPosted: Thu Jan 14, 2021 8:31 am    Post subject: Re: Dual set-up for my ‘51 8n Reply to specific post Reply with quote
Yes, I bought the dual wheel spacers and extenders from you. I recognized them immediately from the picture you posted and thought gee those look familiar.
steve19438
PostPosted: Fri Jan 15, 2021 11:16 am    Post subject: Re: Dual set-up for my ‘51 8n Reply to specific post Reply with quote
do the stud extenders have a part number anywhere ?
michford
PostPosted: Fri Jan 15, 2021 6:30 pm    Post subject: Re: Dual set-up for my ‘51 8n Reply to specific post Reply with quote
Diagram from factory parts manual shows 1132, but part number list does not show it. I also did not find anything in master parts catalog that references pie weight parts.
Page 2 of 2
