changed PTO shaft in the 850
steve in ok
PostPosted: Wed Jan 13, 2021 6:01 am    Post subject: changed PTO shaft in the 850 Reply to specific post Reply with quote
When I changed the PTO shaft the old one came right out but I had to tap the new one in. Not hard to go in. Just concerned I may have hurt something in the trans. It seems to operate good as far as engaging and disengaging. What do you think?
grandpa Love
PostPosted: Wed Jan 13, 2021 6:05 am    Post subject: Re: changed PTO shaft in the 850 Reply to specific post Reply with quote
Should be fine. I've changed 3-4 on my
Fords. Most needed a little tap. Maybe
because they ain't wore out?
steve in ok
PostPosted: Wed Jan 13, 2021 6:20 am    Post subject: Re: changed PTO shaft in the 850 Reply to specific post Reply with quote
Thank you sir, I just wanted a little reassurance I guess. Sure like seeing pictures and videos of your herd of Fords still working.
sotxbill
PostPosted: Wed Jan 13, 2021 6:31 am    Post subject: Re: changed PTO shaft in the 850 Reply to specific post Reply with quote
I just pulled and reinstalled two last week.. Both had to be pulled with a bit of force and reinstalled with the same force. Seals were replace and reinstalled.
Had to use some long screwdrivers to wedge in between, to pull them out...
and tap a hammer to put them back. Both shafts showed to be true and no twist in the splines.
I have pulled some with a some "twist" in them with very long pry bars and a lot of hammer work. Someone probably hit a log or big rock with a shredder to twist the pto shafts.
steve in ok
PostPosted: Wed Jan 13, 2021 10:45 am    Post subject: Re: changed PTO shaft in the 850 Reply to specific post Reply with quote
That's good to know. I feel better about the way mine installed. Thanks
riveroadrat
PostPosted: Sat Jan 16, 2021 5:53 am    Post subject: Re: changed PTO shaft in the 850 Reply to specific post Reply with quote
If someone hammered on the forward end when working on it usually. A little filing on the splines and they slip right in.
