Author |
Message |
rened zuniga Regular
Posted: Wed Jan 13, 2021 5:04 pm Post subject: General Question - engine needs fuel squirt to start |
Not asking for assistance on my Ford tractors but rather for a friend's SCB diesel backhoe.
Seems we got it running and was running fine. However, all of a sudden it will not start unless we squirt some fuel in the air cleaner area.
I am use to working on my simple 8n and 800's but have never worked on diesel.
Any one have an idea what may be the problem?????
As usual, thank you in advance for any suggestions or assistance provided. David |
Back to top |
Dean Tractor Guru
Posted: Wed Jan 13, 2021 7:08 pm Post subject: Re: General Question - engine needs fuel squirt to start |
Fuel or starting fluid? What fuel? Gasoline?
Low cranking speed and/or low compression are two of the most common causes of diesel engine failure to start.
Dean |
Back to top |
Bruce(OR) Tractor Guru
Posted: Thu Jan 14, 2021 5:40 am Post subject: Re: General Question - engine needs fuel squirt to start |
I recently picked up a diesel engine in a 94 IdiT Ford that starting fluid as used on. Complete with two bent push rods and a few other problems. Now it has a new engine in it instead, I guess it could be said a new engine in the long run is cheaper than a proper fix in the first place by the previous owner. Save your pennies, you might be able to purchase it cheap enough, soon enough.
Low batteries and air intrusion are two good places to start looking. Leaky return lines? Leaky o ring at the filters?
if diesel is coming out, air might be getting in. |
Back to top |
showcrop Tractor Guru
Joined: 13 Dec 2000 Posts: 28947 Location: Chester NH
Posted: Thu Jan 14, 2021 7:12 am Post subject: Re: General Question - engine needs fuel squirt to |
You don't give much to go on, but reading between the lines says that MAYBE you did some work like MAYBE replaced filters, and SUDDENLY means that it was doing OK but then things changed. My money would be on sucking a little air while sitting so that it is not getting fuel. |
Back to top |
Jim.ME Tractor Guru
Posted: Thu Jan 14, 2021 8:11 am Post subject: Re: General Question - engine needs fuel squirt to |
Like Dean and showcrop posted, you are leaving a lot out causing people having to guess about here. Maybe you mean JCB loader hoe? What model? What brand engine? What fuel? Are you actually spraying fuel in it or starting fluid? If you did change fuel filters, what did you install for a fuel filter(s) - brand and number? |
Back to top |
grhuck Regular
Posted: Thu Jan 14, 2021 8:37 am Post subject: Re: General Question - engine needs fuel squirt to |
CVPost-rened zuniga wrote: | (quoted from post at 18:04:21 01/13/21) Not asking for assistance on my Ford tractors but rather for a friend's SCB diesel backhoe.
If it's a newer machine with a Common Rail fuel system, call the dealer. Else you may break something that has a price you might not enjoy paying. The newer Common Rail engines set and store malfuntion codes but only a dealer can access them. |
Back to top |
Posted: Thu Jan 14, 2021 5:48 pm Post subject: Re: General Question - engine needs fuel squirt to start |
Sorry for the skippy information, but that's all I was given at first. However, I decided to go over today to look at the backhoe closer during the day. (When I first saw it, it was at night and the guy had a simple hanging light on while working on the engine head.)
Got the serial number and it looks like it is a 1987 JCB B1400 backhoe with a 214 Perkins Diesel engine.
When my friend bought it, the engine head was off. So he had it redone and put it back on with new gasket and all. I went over with my torque wrench to torque the head bolts that evening. Nothing else was done and he indicated it started up fine for about a week. Now it will not start unless a mixture of gas and oil is quirked in the air cleaner passage. Then it works fine until it is time to start it again.
Other than insuring that all fluids are at the proper level, no filters and nothing else has been done or changed.
Will ask my friend to apply your suggestions. Thanks. |
Back to top |
67Chevrolet Regular
Posted: Fri Jan 15, 2021 5:52 am Post subject: Re: General Question - engine needs fuel squirt to |
Maybe retorque head gasket |
Back to top |
