Super Major injector pump drive coupler knocking
FarmallM51
PostPosted: Thu Apr 15, 2021 1:42 am    Post subject: Super Major injector pump drive coupler knocking Reply to specific post Reply with quote
There is a knock coming from the injector pump drive coupling at idle. Is this normal for this tractor? It appears to be the regular Simms pump (not Minimec).
Majorman
PostPosted: Thu Apr 15, 2021 3:33 am    Post subject: Re: Super Major injector pump drive coupler knocking Reply to specific post Reply with quote
Yes, they clatter. There is a rubber cushioned one that was used in the trucks which
can be fitted but the fibre drive ones like you have go for years with a clatter.
You could try slackening off the clamp bolt to the drive shaft and levering the drive
along towards the pump, that will quieten things down for a week or two then the noise
will come back.
SkipperII
PostPosted: Thu Apr 15, 2021 6:10 am    Post subject: Re: Super Major injector pump drive coupler knocking Reply to specific post Reply with quote
When a Major pump drive is rattling, it indicates that the engine is running. Smile Just the nature of the beast.
Vk6zpl
PostPosted: Wed May 05, 2021 6:47 am    Post subject: Re: Super Major injector pump drive coupler knocking Reply to specific post Reply with quote
FarmallM51 wrote:
(quoted from post at 18:42:05 04/15/21) There is a knock coming from the injector pump drive coupling at idle. Is this normal for this tractor? It appears to be the regular Simms pump (not Minimec).
You could try neoprene board same material used on prime movers skid plate.
Post new topic    Yesterday's Tractors Forum Index -> Fordson All times are GMT - 8 Hours
