Allis Chalmers Plow model question
Dutchman1968
PostPosted: Sun Apr 18, 2021 4:51 am    Post subject: Allis Chalmers Plow model question Reply to specific post Reply with quote
Hello All,
I just purchased this plow at an auction to do some light plowing. Does anyone know what model of plow this is and what era it was made? Are they any good or light duty?
Thanks,
Dutch
Aaron SEIA
PostPosted: Mon Apr 19, 2021 3:07 am    Post subject: Re: Allis Chalmers Plow model question Reply to specific post Reply with quote
I've gotta say that doesn't look AC to me. Parts of it does, but that tail wheel setup is something I've never seen before.
AaronSEIA
DrAllis
PostPosted: Mon Apr 19, 2021 3:22 am    Post subject: Re: Allis Chalmers Plow model question Reply to specific post Reply with quote
50-series 3-point hitch plow with an optional tail wheel that I've never seen before. Must have been for a D-10/D-12.
BonaparteSouth
PostPosted: Mon Apr 19, 2021 5:00 am    Post subject: Re: Allis Chalmers Plow model question Reply to specific post Reply with quote
doesn't look AC to me. mostly pieces from junk pile and late night booze crew welding shop !! lol one of a kind
4wdtom
PostPosted: Mon Apr 19, 2021 5:15 am    Post subject: Re: Allis Chalmers Plow model question Reply to specific post Reply with quote
I am no expert on AC plows but it does look to me like the frame (horizontal parts and the vertical stub beam that extends down to the plow bottoms, and the gusset plate that braces the stub beam) and details of construction is AC. The lower bolt in the gusset plate is referred to in the parts list for my WD no. 54 Two Way Plow as a special bolt. I don't know what makes it special. I do know it is meant to shear if you hit a rock or something else to prevent more serious damage. From my experience I use a grade two in that position and a length that will allow the full diameter, (not the threaded portion), to be at the joint or seam between the gusset plate and the stub beam. For the upper bolt that holds the frame, gusset plate, and stub beam I use a grade 8 as you don't want that one to shear or to be partially sheared as it is a lot harder to replace especially on my roll over plow as it also holds the opposite such parts too and a partially sheared bolt is very difficult to remove if the other end has been sheared off. May not apply to a non roll over. Still I would recommend a grade 8 for the main pivot bolt and of a length that doesn't have threads where the shear will be. The coulters also look to be AC to me. The tail wheel looks like it could have been a bolt on option, not a farmer made add on as the S curve wouldn't have been done by the average person adding such.
wolfman
PostPosted: Sat Apr 24, 2021 4:13 pm    Post subject: Re: Allis Chalmers Plow model question Reply to specific post Reply with quote
Your basic model 62 with a lot of homemade hitch and tailwheel jerryrigging. I have a new landslide for an AC mounted plow in the shed.
DrAllis
PostPosted: Sat Apr 24, 2021 4:49 pm    Post subject: Re: Allis Chalmers Plow model question Reply to specific post Reply with quote
60/62 series have angled beams for the bottoms to connect to, similar to the 70 series. That is a 50/52 series because they are straight down beams.
