David from Kansas - grain drill advice/parts
Goto page Previous  1, 2
Tx Jim
PostPosted: Tue Apr 20, 2021 3:26 am    Post subject: Re: David from Kansas - grain drill advice/parts Reply to specific post Reply with quote
To determine if double disk boots in lieu of single disk boots can be utilized one will need to know both model of Dawg's & rusty's drills then perform parts research.
I think the different type boots will interchange if boots are equipped with correct attaching hardware.
David from Kansas
PostPosted: Tue Apr 20, 2021 6:37 am    Post subject: Re: David from Kansas - grain drill advice/parts Reply to specific post Reply with quote
I have some new old stock single openers. When I researched the numbers it seems some of the openers are interchangeable with different models of
drills, like Tx Jim said. Also have some good used ones, more of one side than the other (L & R). Will look for some pics, or get some new ones.
I think I have a couple of different styles/part numbers. The pic is of the style that I have several of, think the pic might be of a slightly used
one. Thanks. Email is open.
Dawg in Fl
PostPosted: Tue Apr 20, 2021 6:53 am    Post subject: Re: David from Kansas - grain drill advice/parts Reply to specific post Reply with quote
I can't see your email - maybe I don't have enough posts to have access yours?
mine's WiJMjr@gmail.com
David from Kansas
PostPosted: Tue Apr 20, 2021 7:19 am    Post subject: Re: David from Kansas - grain drill advice/parts Reply to specific post Reply with quote
Sent you an email just a few minutes ago. Thanks.
David
Tx Jim
PostPosted: Tue Apr 20, 2021 7:37 am    Post subject: Re: David from Kansas - grain drill advice/parts Reply to specific post Reply with quote
Dawg
I also sent you an email.
Jim
Tx Jim
PostPosted: Tue Apr 20, 2021 7:52 am    Post subject: Re: David from Kansas - grain drill advice/parts Reply to specific post Reply with quote
I recieved your email. Now I know your drill is a model "B" cut in half to be used for food plot. I sent you another email with some info.
Habitat1
PostPosted: Mon Apr 26, 2021 8:14 am    Post subject: Re: David from Kansas - grain drill advice/parts Reply to specific post Reply with quote
I bought rubber ones from JD
Habitat1
PostPosted: Fri May 28, 2021 8:57 am    Post subject: Re: David from Kansas - grain drill advice/parts Reply to specific post Reply with quote
It seems like you know your JD drills,what about planters.I am still trying to figure out what this is for sure.It's in good shape and I have new tires for it but think I will sell as I do no till
TerapinChef
PostPosted: Tue Jun 15, 2021 6:22 pm    Post subject: Re: David from Kansas - grain drill advice/parts Reply to specific post Reply with quote
Youre looking for the actual boot that fits behind the disc and receives the seed from the tube, correct? Which side boot do you need because I believe they are left and right handedif you are still in need I may have a few in the near future, I think Im going to cut this bad boy down a bit
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
Page 2 of 2
