How much paint for rims??
super99
PostPosted: Sat Apr 24, 2021 3:08 am    Post subject: How much paint for rims?? Reply to specific post Reply with quote
I'm trying to get my Oliver 1550 looking gooder than it was, both front and rear rims, cast grill, name spears on the hood and the panels in the fenders for the lights. I have already painted the dash with a spray can. How much paint will I need to paint rims, grill etc?? I have a quart of Agco Clover white, but I doubt the that's enough. Thanks, Chris
showcrop
PostPosted: Sat Apr 24, 2021 5:15 am    Post subject: Re: How much paint for rims?? Reply to specific post Reply with quote
I estimate that you have 30 square feet to cover, and a quart should cover 100.
super99
PostPosted: Sat Apr 24, 2021 6:29 am    Post subject: Re: How much paint for rims?? Reply to specific post Reply with quote
Sorry, I should have added the cast rear wheel centers also.
showcrop
PostPosted: Sat Apr 24, 2021 8:20 am    Post subject: Re: How much paint for rims?? Reply to specific post Reply with quote
CVPost-super99 wrote:
(quoted from post at 07:29:50 04/24/21) Sorry, I should have added the cast rear wheel centers also.
I was figuring tin one piece rears.
showcrop
Tgrasher
PostPosted: Sat Apr 24, 2021 10:18 am    Post subject: Re: How much paint for rims?? Reply to specific post Reply with quote
I believe showcrop is correct, your at that point of should you buy a gallon or two more quarts. If you could take the quart back and exchange it for a gallon, you would end up with spare paint for future use with just a little more money.
Stephen Newell
PostPosted: Sat Apr 24, 2021 4:00 pm    Post subject: Re: How much paint for rims?? Reply to specific post Reply with quote
If you are spraying it a quart should be more than enough to paint the rims and grille unless you plan to use more than two coats.
showcrop
PostPosted: Sat Apr 24, 2021 7:35 pm    Post subject: Re: How much paint for rims?? Reply to specific post Reply with quote
CVPost-Tgrasher wrote:
(quoted from post at 11:18:06 04/24/21) I believe showcrop is correct, your at that point of should you buy a gallon or two more quarts. If you could take the quart back and exchange it for a gallon, you would end up with spare paint for future use with just a little more money.
My math says that a quart is three times what is needed. I don't see any need for a gallon.
Geo-TH,In
PostPosted: Sun Apr 25, 2021 11:19 am    Post subject: Re: How much paint for rims?? Reply to specific post Reply with quote
When I spray rims, I use paint brush and coat rubber with used motor oil. Spray it and immediately use rag and diesel to wipe off rubber. Can use mineral spirits or gas if you are brave and Barney isn't around.
George
SVcummins
PostPosted: Tue May 04, 2021 9:17 pm    Post subject: Re: How much paint for rims?? Reply to specific post Reply with quote
Stephen Newell
PostPosted: Wed May 05, 2021 6:08 pm    Post subject: Re: How much paint for rims?? Reply to specific post Reply with quote
A quart of paint will cover 80-90 square feet. The centers won't add that much.
Post new topic    Yesterday's Tractors Forum Index -> Paint and Bodywork All times are GMT - 8 Hours
