diverter valve for CA?
J&J
PostPosted: Sat Apr 24, 2021 8:25 am    Post subject: diverter valve for CA? Reply to specific post Reply with quote
I have a 52 CA with a model 8 trip loader and snap coupler blade. I'd like to mount Both to the tractor without the hydraulics interfering with one another. Is a diverter valve what I'm needing? If so, would I need to reroute the lift cylinders along with the loader cylinders directly to the diverter valve with one line from the pump to the valve? Any recommendations on a good reasonalbly price valve?
Any other suggestions on how to accomplish this?
DrAllis
PostPosted: Sat Apr 24, 2021 5:32 pm    Post subject: Re: diverter valve for CA? Reply to specific post Reply with quote
I think you're asking about a simple push/pull valve that has 3 ports. One port for the pump......one port for the blade.....one port for the loader. You set the valve for the blade and raise the blade off the ground and switch the valve to the loader and the blade stays raised up and the loader can then be used up and down and hold. To use the blade, you raise the loader up off the ground a couple feet and switch the valve and then use the blade while the loader is locked up off the ground. This system requires some oil level management on your part, as some oil is always missing from the sump when it is holding up one of the implements. Surplus Center in Nebraska item 9-6133 Prince selector valve 3/8" pipe threads 20 GPM $79.00
4wdtom
PostPosted: Sun Apr 25, 2021 5:46 am    Post subject: Re: diverter valve for CA? Reply to specific post Reply with quote
You could Tee into the line with a valve to each implement, opening the one you wanted to function I would think.
