JD model E
Mark Poss
PostPosted: Wed Apr 28, 2021 7:33 am    Post subject: JD model E Reply to specific post Reply with quote
I want to put new piston rings in a 1.5 hp. JD model E. Whats
the best way to remove the piston? Doesnt look like it will
clear the governor gear if I try to pull it out the back. Any help
is appreciated. Thanks Mark
wore out
PostPosted: Wed Apr 28, 2021 11:04 am    Post subject: Re: JD model E Reply to specific post Reply with quote
[quote="CVPost-Mark Poss"]/quote]
Since the cylinder head is removable on these engines I'm wondering why you are trying to remove the piston in the other direction, is it because of rust or a deep "ridge" in the sleeve?
If you don't already have the head off I would think you why also want to check the valves and grind them if needed.
Johndeereguy37
PostPosted: Thu Apr 29, 2021 3:31 pm    Post subject: Re: JD model E Reply to specific post Reply with quote
Hey Mark,
You'd really be best to remove the cylinder head and remove the piston from the front. Not only will this allow you to install the piston because there is a chamfer in the front of the cylinder to install the piston and rings easily, it would allow you to clean the water jacket on a 3 or 6 horse. On your 1.5 it is a air cooled head so the water jacket doesn't go into the head so that doesn't help...
I've found in the few of these that I've done compression and oil burning can often be caused because the front ring is sticky in it's groove. Often times it can be cleaned and reinstalled if you'd like.
Hope I could help.
JB
Mark Poss
PostPosted: Fri Apr 30, 2021 1:17 pm    Post subject: Re: JD model E Reply to specific post Reply with quote
Thanks for your help guys. Im going to pull the head and bring it out the front
Post new topic    Yesterday's Tractors Forum Index -> Stationary Engines All times are GMT - 8 Hours
