Trouble posting
used red MN
PostPosted: Fri Apr 30, 2021 8:10 pm    Post subject: Trouble posting Reply to specific post Reply with quote
YT Support I am trying to post this in reply to Farmer Abe. I think it may be because it is a reply to a broken post because it was an older post in Tractor Talk the topic is ..OT New Holland 6635.. I want to say... Farmer Abe welcome to YT. You replied to nearly the last post Kenny kabot posted here in Fall of 2020. In other words unless he reads and does not post you probably wont hear anything from him. A little more direct approach would be to send him an email. I assume you viewed the post on ..Modern View.. Click ..Classic View.. in the red box at the top, hopefully when viewing there you will see a box in the lower right of his reply to send an email. I agree with getting the parts diagram to possibly help you see what your problem is. The factory parts sight is down today they must be updating. Otherwise I would try to see if your tractor is considered to be in their group and post a link to the online parts page. If you are thinking about attempting the repair yourself I would suggest buying a repair manual for your tractor. Best of luck.... Any ideas
used red MN
PostPosted: Fri Apr 30, 2021 8:15 pm    Post subject: Re: Trouble posting Reply to specific post Reply with quote
I that post initially did not preview using the ..Preview.. button. I used the Submit button and it went okay. I mostly post on Classic so I am used to getting the Preview option. I will go back to the post and see if I use Submit there if it will go through. Thanks!
YTSupport
Site Admin
PostPosted: Sat May 01, 2021 5:12 am    Post subject: Re: Trouble posting Reply to specific post Reply with quote
I would expect problems replying to posts older than a certain date earlier this year when I put the new version of classic in, though from your description, it almost sounds like a different sort of issue.
Replying to old posts is always a problem though. You can do it with Modern view, but it will always create a broken post in classic because it has no thread to relate it to. The threads roll off the main board in classic and reply to such never works without problems. This also doesn't fully explain what you describe. I may not be fully understanding though.
Post new topic    Yesterday's Tractors Forum Index -> Site Comments All times are GMT - 8 Hours
