Why is it bouncing?
Goto page Previous  1, 2
Geo-TH,In
PostPosted: Sun May 16, 2021 4:35 am    Post subject: Re: Why is it bouncing? Reply to specific post Reply with quote
When my trailer is empty it has the same bouncing problem. My smallest tractor 3100# stops the bouncing.
Trailer bounced more than ever.
I discovered one 10 year old tire was coming apart. New tires helped a little.
I think the harmonic bouncing may be fixed with shock absorbers.
Weight on trailer solves my bouncing.
Try playing with air pressure. Reduce air pressure when not carrying max load. Monitor tire temperature with IR thermometer.
Geo-TH,In
PostPosted: Sun May 16, 2021 4:46 am    Post subject: Re: Why is it bouncing? Reply to specific post Reply with quote
Pete, I thought I was responding to author. Sorry.
BarnyardEngineering
PostPosted: Mon May 17, 2021 3:55 am    Post subject: Re: Why is it bouncing? Reply to specific post Reply with quote
Geo, your trailer axles are slightly misaligned. One axle is going one way, the other axle is going in a slightly different direction. They get far enough apart and POP, the trailer bounces.
With the weight of the tractor it forces the tires to scrub. Probably why one of them was bulging.
That's why you test tow new tandem axle trailers before handing over any money. If it bounces, take it back and get a different one.
showcrop
PostPosted: Mon May 17, 2021 4:00 am    Post subject: Re: Why is it bouncing? Reply to specific post Reply with quote
BarnyardEngineering wrote:
(quoted from post at 04:55:43 05/17/21) Geo, your trailer axles are slightly misaligned. One axle is going one way, the other axle is going in a slightly different direction. They get far enough apart and POP, the trailer bounces.
Barnyard, please tell how you made your measurements. The world needs to know!
J.Wondergem
PostPosted: Mon May 17, 2021 5:30 am    Post subject: Re: Why is it bouncing? Reply to specific post Reply with quote
showcrop wrote:
(quoted from post at 08:00:32 05/17/21)
I can tell you how I do it. Take a SMALL cable, make a loop around the hitch, on a goose neck, and stretch it back to the axle on both outer sides in the exact same spots. I learned that way from the truck garage where I worked. They aligned semi axles that way.
Geo-TH,In
PostPosted: Mon May 17, 2021 9:09 am    Post subject: Re: Why is it bouncing? Reply to specific post Reply with quote
You may be right. I measured everything, It
checks out all good.
My 10k dump trailer works flawlessly at all
speeds.
I only have bouncing when empty around 35 mph. .
If I have to go a long distance empty, I reduce
air pressure and bouncing is also reduced.
jdknucklebuster
PostPosted: Thu May 20, 2021 6:26 pm    Post subject: Re: Why is it bouncing? Reply to specific post Reply with quote
I'm torn between comments made by Barnyard and Dr. Evil. I have multiple trailers and one of my tandem dual trailers
is also a hopper when empty. Kinda eliminates the load the tractor here or there comments. I was thinking about
Barnyard's theory of axle alinement and it really make sense. I like that idea. Dr Evil's comment of length of
trailer and axle spread or good too. I have a 35' Big Tex 12k with wide spread axles and that trailer pulls like a
dream. No hoppy or yanking. I know it has something to do with that distance between the truck wheels and trailer's
wheels in relationship to the bump in the road. Those two problems are completely different in my opinion.
caterpillar guy
PostPosted: Sat Jun 19, 2021 1:56 am    Post subject: Re: Why is it bouncing? Reply to specific post Reply with quote
In MI that is the norm for roads just have to live with it. I-69 from Lansing to Perry you can't hardly stay in the seat and I-94 around west of PawPaw is about the same in a semi. Most of MI unless they just layed it is that way. They can't seem to get a bridge and road at the same plain either.
CaseDC3
PostPosted: Fri Jun 25, 2021 3:12 am    Post subject: Re: Why is it bouncing? Reply to specific post Reply with quote
Where did you rent that truck and trailer? Seems like it would be a handy option now and then.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Transporting All times are GMT - 8 Hours
Page 2 of 2
