VAC driving me nuts
old
PostPosted: Mon May 03, 2021 2:44 pm    Post subject: VAC driving me nuts Reply to specific post Reply with quote
So I have been trying to get a VAC running again. I've had it try to run many times but not run for more then a minute or so. Thought it was the carb so took carb off one that runs well. Still didn't run. Lost spark but has new points. Found wire had shorted out to the oil filter. Got that taken care of and got it to run just to find out the generator is locked up so belt started smoking. Oh well at least it did run and now on to things like making sure the radiator is good etc.
John Saeli
PostPosted: Mon May 03, 2021 4:20 pm    Post subject: Re: VAC driving me nuts Reply to specific post Reply with quote
Well I'd say that's progress!!
old
PostPosted: Mon May 03, 2021 4:43 pm    Post subject: Re: VAC driving me nuts Reply to specific post Reply with quote
Yes a little bit of it. The one I have been trying tot get to run now has a carb off a known good runner and the good runner now has the carb off the non running one and yet both now run
Tgrasher
PostPosted: Mon May 03, 2021 6:47 pm    Post subject: Re: VAC driving me nuts Reply to specific post Reply with quote
Your doing better than me, used a 300 that I thought I had everything fixed to spread fertilizer. Worked great, washed the dust off when I got done and left it set to dry. Started it later to put it away and oil starts coming out the timing hole in the bell housing. Drove it to the shed and parked it.
