Sand blaster
Goto page 1, 2  Next
SVcummins
PostPosted: Mon May 03, 2021 9:44 pm    Post subject: Sand blaster Reply to specific post Reply with quote
Anyone have one of these
Sand blaster
big jt
PostPosted: Mon May 03, 2021 10:23 pm    Post subject: Re: Sand blaster Reply to specific post Reply with quote
Yep I got one. Not a harbor fraught, Think it is either Northern Tool or one of those tent sale outfits. Works pretty good for small jobs with a 5 hp two stage compressor.
Not a production unit but works pretty well for what it is.
jt
Fawteen
PostPosted: Tue May 04, 2021 2:20 am    Post subject: Re: Sand blaster Reply to specific post Reply with quote
Got one from Tractor Supply. Haven't used it much, but did the job I bought it for. At that price, I don't mind storing it until that once a year I need it.
Butch(OH)
PostPosted: Tue May 04, 2021 2:50 am    Post subject: Re: Sand blaster Reply to specific post Reply with quote
There is one out buried in the junk pile. Fitting on the bottom where the sand and air mix didn't last 2 bags of sand and had a hole in it, was made of potmetal. Fixed that up with some pipe fittings. Hose got real stiff after a while and the blasting valve leaked like a sieve. Tired of the aggravation and tossed it. Bought a Brut 101H, made near by and what I should have bought in the first place, now that's a sand blaster.
ray hofstetter
PostPosted: Tue May 04, 2021 2:59 am    Post subject: Re: Sand blaster Reply to specific post Reply with quote
Bought the exact same thing at work a few years ago for a small job, never could get it to work and threw it in the junk pile....
RobCons
PostPosted: Tue May 04, 2021 3:08 am    Post subject: Re: Sand blaster Reply to specific post Reply with quote
I've got that one. It needs a lot of air and is still slow. I use a 60 gallon compressor that puts out around 14 - 17 cfm and it can barely keep the pressure at 50 lbs. The blast area is very small, about the size of a quarter at best. The ceramic tips wear out fairly often and as the hole gets bigger more air is required. Sand and air have to be bone dry to prevent clogging.
showcrop
PostPosted: Tue May 04, 2021 3:37 am    Post subject: Re: Sand blaster Reply to specific post Reply with quote
I have one. It works but it is slow due to the tendency to plug at the point where the sand drops into the air flow.
warbaby
PostPosted: Tue May 04, 2021 4:29 am    Post subject: Re: Sand blaster Reply to specific post Reply with quote
I had the same problem- the point where the sand enters the airstream from the pressure tank is a major clogging point. I fixed it by adding a valve upstream
right under the tank before the mixing point to control the amount of sand entering the tube. Now it works great! I just barely crack that valve and get the sand
flowing, then adjust the flow via the valve for the work I'm doing. When I finish, or stop for a minute to rearrange the part I'm blasting, I shut the valve off
and clear the hose of any sand. This way eliminates any clogging and saves CFMs.
Add to that to my portable sand blasting booth (a 5x10 trailer with full plywood front and sides, hung with tarps to catch the sand to strain and reuse it) a
hazmat-like suit with filtered breathing air (THE MOST IMPORTANT TOOL FOR BLASTING!) and a 2 stage compressor, I can blast all day, or at least until the wife
hangs some clothes out...
DoubleO7
PostPosted: Tue May 04, 2021 5:23 am    Post subject: Re: Sand blaster Reply to specific post Reply with quote
Just don't get the siphon type unit.
Pressurized tank for sure.
I would get the style like pictured but the upper tank head is upside down. Which works as a funnel when pouring in the sand.
Do not plan on digging your own sand or using play sand from the store.
Only buy blasting media be it sand, cinders, walnut shells, baking soda, etc.
1948CaseVAI
PostPosted: Tue May 04, 2021 5:29 am    Post subject: Re: Sand blaster Reply to specific post Reply with quote
IIRC Keith Rucker on youtube has a video about how to beef up the HF blaster to make it better.
diesel fumes
PostPosted: Tue May 04, 2021 5:50 am    Post subject: Re: Sand blaster Reply to specific post Reply with quote
you need a very large compressor ,or you will constantly be waiting for it to catch up; steel nozzles last longer than ceramic. please be very aware of the danger of silica to your lungs! i have 2 blasting cabinets and a pressure pot -a 15hp compressor and when i need something blasted at this point i usually take the stuff to a local blaster, except for cabinet blasting.
Mike(NEOhio)
PostPosted: Tue May 04, 2021 6:50 am    Post subject: Re: Sand blaster Reply to specific post Reply with quote
I have a home built one similar to that. My 13 CFM compressor isn't quite enough but I don't use it a lot. Blasting is really fun . . . . . for about fifteen minutes.
thdrduck
PostPosted: Tue May 04, 2021 11:18 am    Post subject: Re: Sand blaster Reply to specific post Reply with quote
I have that one and a commercial one and a cabinet. For mid size jobs the HF one works good. Air use depends on the size of tip you use, bigger the tip the more air you use. Also most plugging issues come from folks trying to push too much sand through it too fast or not using dry air and sand. A respirator is a must no matter the media. The hood that comes with it will work but barely. The best investment you can make is a roll of clear film to tape over the lens, change the film, not the lens. I think Brute carries it along with other odds and ends. Sorry, nuff said.
MasseyHarrisGuy
PostPosted: Tue May 04, 2021 3:59 pm    Post subject: Re: Sand blaster Reply to specific post Reply with quote
I have the same blaster as Double07. top of the tank has a dish to it to funnel the sand and a hand sized hole to put the sand in. I bought it at harbor freight 10 years ago. It had basically the same hand valve and bottom valve as the one in your pic. I used the snot out of that blaster and I still use it to this day. Last year I used it to blast the body panels on my B61 Mack to repaint. Sure I made some repairs, new homemade hand valve and a new longer hose but I got my $139 worth of use out of it. Like what was said, you need DRY sand. With the emphasis on DRY! Start with the tank and blast pressure valve open and the bottom valve (sand valve) closed and crack slowly until you get a good blast pattern going. You dont want the sand to be visable in the stream. If you can see the sand, your wasting it. I ran mine with a larger upright compressor, but later switched to a schramm 100cfm. NO air consumption problems now!
SVcummins
PostPosted: Tue May 04, 2021 4:42 pm    Post subject: Re: Sand blaster Reply to specific post Reply with quote
My compressor is a16 scfm maybe I should look at the smaller blaster .
Goto page 1, 2  Next
Page 1 of 2
