Timing marks?
Ehud
PostPosted: Tue May 04, 2021 3:22 pm    Post subject: Timing marks? Reply to specific post Reply with quote
Hey everyone. I was replacing the main bearings on my '52 8n. In the process the front of the crankshaft dropped a little and I lost the timing with the cam. Is ther a way to find the timing mark on the cam gear without removing the timing cover? I can see a couple tooth faces but without having an idea of where the mark is I can't seem to find it. I'm can pull the cover but I'd really like to avoid it.
kris Jensen
PostPosted: Tue May 04, 2021 3:49 pm    Post subject: Re: Timing marks? Reply to specific post Reply with quote
Hello.
If you turned the crank after it dropped, and I suspect you might have,
then you may as well pop the cover and save yourself a lot of frustration.
If perchance you did not turn it then you should be able to lift it back up
and have it match. good luck to you
Ehud
PostPosted: Tue May 04, 2021 3:53 pm    Post subject: Re: Timing marks? Reply to specific post Reply with quote
It definitely turned, I really don't want to have to wait for another gasket to arrive and dealing with the distributor timing and everything with that cover.
JMOR
PostPosted: Tue May 04, 2021 4:26 pm    Post subject: Re: Timing marks? Reply to specific post Reply with quote
Just a "maybe" here. Pull gov and see if a very thin mirror will slide between cam gear & timing cover.
Hobo,NC
PostPosted: Tue May 04, 2021 5:03 pm    Post subject: Re: Timing marks? Reply to specific post Reply with quote
I can't imagine it dropping that far...
Ehud
PostPosted: Tue May 04, 2021 6:14 pm    Post subject: Re: Timing marks? Reply to specific post Reply with quote
I wasn't having a really smart day and loosened all 3 bearings at once. I pulled the timing cover and got it properly set, after I get a new gasket for the timing cover I'll finish it up.
