Re: 1370 transmission filter gauge problem
1370rod
PostPosted: Tue May 04, 2021 6:26 pm    Post subject: Re: 1370 transmission filter gauge problem Reply to specific post Reply with quote
Hmmm, I wonder if you have something restricting oil coming through the suction screen. At idle there is sufficient oil coming through to meet the demands of the
hydraulic pump and then some which would result in pressure showing on filter gauge. But at higher rpm's the hydraulic pump output increases and so is the need to supply
filtered oil to it. If the supply available to the charge pump is limited by a restricted screen the filter pressure would then go down. Just a guess without knowing more
about problem or additional testing, Rod.
mEl
PostPosted: Wed May 05, 2021 3:05 am    Post subject: Re: 1370 transmission filter gauge problem Reply to specific post Reply with quote
Rod, Your theory is what I was thinking also, the other thing I was considering was a valve that regulates the charge pressure being faulty or dirty, I was looking at the parts site and there is a regulator valve shown on the page with the filters, is it up in the filter cavity, I have never had this issue so not really qualified to input on it.
