Case 930 hard starting
NFD17
PostPosted: Wed May 05, 2021 4:17 am    Post subject: Case 930 hard starting Reply to specific post Reply with quote
My Case 930 used to bust off in a rev or two, then about a year ago a
neighbors dope head grown son went in the shed and got the tractor
without permission. He used the tractor to pull his truck out of another
persons field where he got stuck while stealing parts off of one of that
mans trucks. He wrapped a chain in such a way that he jerked the lower
radiator hose off and wound up running the tractor hot, how hot I dont
really know but the gauge was not pegged out and stuck so I hoped
maybe not that bad or not too long. Since that all took place the tractor
has been extremely hard starting and black smokes when it finally does
start, I have run it long enough to make sure no water getting in the oil
and not overheating while running, otherwise thinking he might have
done something else to the tractor at the same time. Appreciate any
suggestions on what to check.
John Saeli
PostPosted: Wed May 05, 2021 7:06 am    Post subject: Re: Case 930 hard starting Reply to specific post Reply with quote
This is a tough 1. But, do you really know how hot it got? Air restriction will cause black smoke, but shouldn't cause hard starting unless something catastrophic happened to the air intake. Check that out,; after that do a compression check.
NFD17
PostPosted: Wed May 05, 2021 9:10 am    Post subject: Re: Case 930 hard starting Reply to specific post Reply with quote
No, I do not know how hot it got, I will get the book and do a compression check, thanks.
Bruce from Can.
PostPosted: Wed May 05, 2021 6:10 pm    Post subject: Re: Case 930 hard starting Reply to specific post Reply with quote
From what you have told us, I cant help but wonder if this stunt might have damaged the valves in the head. There by cutting the compression.
