Question on clutch joint ring coupling on H ?
blueridge
PostPosted: Thu May 06, 2021 4:25 pm    Post subject: Question on clutch joint ring coupling on H ? Reply to specific post Reply with quote
That is what the parts book calls it, the square coupling that the bolts go through, are the tapered bolts supposed to fit tight in the square coupling? Holes do not appear to be rounded out very much, but I got new bolts from Steiner and they are loose in holes, also got new rubbers. When I restored this H 12 years ago I welded up bolts to fit holes tighter, bolts were wore bad. I have read these topics for a few years and do not remember anyone asking about this. I have another square coupling off a parts H and it is about the same as this one. Thought maybe someone had ran into this. I just installed new bearings in the top shaft in trans. Wanting to get everything together tight. Thanks for any help, I have not seen any new ones anywhere either. Gene
pete 23
PostPosted: Thu May 06, 2021 5:33 pm    Post subject: Re: Question on clutch joint ring coupling on H ? Reply to specific post Reply with quote
The bolts should not be tight in the coupling ring but not slopping loose either. A new ring and new bolts the bolts would fit freely in coupler. New rubbers should clamp ring tightly though. Not that they would stay that tight after being compressed for a while. As long as it does not wobble when running you will be ok.
FBH44
PostPosted: Sat May 08, 2021 2:26 pm    Post subject: Re: Question on clutch joint ring coupling on H ? Reply to specific post Reply with quote
Be aware, that coupler can go back together two ways. Mount it so there is the maximum open space inside it, not the minimum. If you mount it with the minimum space inside, the end of the drive shaft will not fit into the needle bearing pilot bearing, and it'll flap around and flop around and destroy things. BTDT.
