Farmall 656 Floor Pan Removal
big a
PostPosted: Thu May 06, 2021 6:25 pm    Post subject: Farmall 656 Floor Pan Removal Reply to specific post Reply with quote
Only other 656 I ever took the floor pan out of had about an inch trimmed off the right rear corner. Always wondered why until tonight.
Got some wiring underneath I need to get at, so its got to come off.
Got all the bolts out and absolutely cannot get that darn thing forward enough to get the rear of it to come up past that hydraulic manifold block.
Do clutch and brake pedals have to come off to remove this thing?
Seems like that is the only way I am going to get it off.
Cant believe something so simple is kicking me so hard![/u]
pete 23
PostPosted: Thu May 06, 2021 7:51 pm    Post subject: Re: Farmall 656 Floor Pan Removal Reply to specific post Reply with quote
Push the clutch and brake way down, tie them if necessary. Or, you can cut
that little part off before you remove pan. Also, make sure brake lock is
unhooked underneath.
I always modify the pan before putting it back on. You are right, a pain for
such a simple job.
Anther thing I did was get rid of the front hydraulic outlets and pipes. Then
you can make a lot of repairs a lot easier. Need a couple or four shorter
banjo bolts fastening lines to valves.
big a
PostPosted: Sat May 08, 2021 12:07 pm    Post subject: Re: Farmall 656 Floor Pan Removal Reply to specific post Reply with quote
Thanks Pete!
Glad to know its doable w/o tearing more stuff apart.
I like the idea of removing those front remote tubes, but they are handy for a loader.
You are a wealth of knowledge!
ejr-IA.
PostPosted: Sat May 08, 2021 4:14 pm    Post subject: Re: Farmall 656 Floor Pan Removal Reply to specific post Reply with quote
brake springs
