886 358 diesel setting valves tsc marks cant find
Joshbraman
PostPosted: Sat May 08, 2021 9:42 am    Post subject: 886 358 diesel setting valves tsc marks cant find Reply to specific post Reply with quote
I have a dilemma we redid the head on our 886 d358. We got It back on but we cant find any marking on the front pulley to set it at TDC. We even looked in the flywheel housing and nothing there. the front pulley the metal arrow is there. We noticed there seems to be a material on the pulley and we were wondering if it was printed instead of engraved on the pulley. Any help is greatly appreciated
teddy52food
PostPosted: Sat May 08, 2021 10:19 am    Post subject: Re: 886 358 diesel setting valves tsc marks cant find Reply to specific post Reply with quote
Set one cylinder on the rock then set the valves on the running mate.
rustred
PostPosted: Sat May 08, 2021 10:31 am    Post subject: Re: 886 358 diesel setting valves tsc marks cant find Reply to specific post Reply with quote
yep, dont need marks to set valves. follow firing order or the simplified method,... no need for marks. for #1 cyl. on TDC get #6 in the centre of the rock.
Joshbraman
PostPosted: Sat May 08, 2021 10:37 am    Post subject: Re: 886 358 diesel setting valves tsc marks cant find Reply to specific post Reply with quote
Could you please give a little more detail. I think I know what you mean but I want to make sure
used red MN
PostPosted: Sat May 08, 2021 11:11 am    Post subject: Re: 886 358 diesel setting valves tsc marks cant find Reply to specific post Reply with quote
Okay let see how this goes. What they are talking about is when number one cylinder is on TDC compression its running mate No 6 is on valve overlap meaning the exhaust valve is just closing and the intake is just opening. The link explains it more. Write down the firing order on a paper along the left edge; 1-5-3-6-2-4 then next to them write 6-2-4-1-5-3. So after you set No1 valves with 6 on overlap, turn the engine to No 2 overlap and set the valves on No 5 and so on until all 6 in the firing order have been adjusted.
More info
the tractor vet
PostPosted: Sat May 08, 2021 11:46 am    Post subject: Re: 886 358 diesel setting valves tsc marks cant find Reply to specific post Reply with quote
To do the valve adjustment on a 358 turn engine so that #1 is at TDC then set the valves on #1 or as we say 1&2 skip # 3 then do 4&5 skip 6&7 do 8&9 . Turn engine one full turn and do #3 -6&7 -10-11-12 .
used red MN
PostPosted: Sat May 08, 2021 11:57 am    Post subject: Re: 886 358 diesel setting valves tsc marks cant find Reply to specific post Reply with quote
TV and if they cannot find TDC like they ..SAID.. in their post then how have you helped them? I realize I could have given them that procedure once they knew how to find TDC by valve overlap, but that was not the process in discussion.
used red MN
PostPosted: Sat May 08, 2021 12:01 pm    Post subject: Re: 886 358 diesel setting valves tsc marks cant find Reply to specific post Reply with quote
If you want to make a new mark at exactly TDC I can tell you how to find the precise TDC, if this tractor has pencil injectors it would be real easy.
Dieseltech
PostPosted: Sat May 08, 2021 1:43 pm    Post subject: Re: 886 358 diesel setting valves tsc marks cant find Reply to specific post Reply with quote
I do it this way,
1 5 3
6 2 4
When 1 has ex almost closed and in started open on overlap set 6. turn 1/3 turn to 5 overlap set 2, turn 1/3 turn to 3 overlap set 4
Turn 1/3 turn to 6 overlap set 1, turn 1/3 to 2 overlap set 5, turn 1/3 turn to 4 overlap set 3, and you are done..
Same way on four cylinders, just turn by 1/2 turn.
1 3
4 2
rustred
PostPosted: Sat May 08, 2021 2:52 pm    Post subject: Re: 886 358 diesel setting valves tsc marks cant find Reply to specific post Reply with quote
here is the simplified method , much less confusing the the beginners.
used red MN
PostPosted: Sat May 08, 2021 3:27 pm    Post subject: Re: 886 358 diesel setting valves tsc marks cant find Reply to specific post Reply with quote
DT Humm, exactly what I posted.... no offense.
MARK ROBKE
PostPosted: Sat May 08, 2021 4:26 pm    Post subject: Re: 886 358 diesel setting valves tsc marks cant find Reply to specific post Reply with quote
I was taught this way also-it was called the magic #7. What ever valve set 'rocks'-exhaust closing and intake opening, both are tight, then the opposite valve set will be ready to adjust, and it will add to that # and it will = 7 ! 1&6, 2&5, 3&4. Firing order is always 153624. Mark.
the tractor vet
PostPosted: Sat May 08, 2021 7:41 pm    Post subject: Re: 886 358 diesel setting valves tsc marks cant find Reply to specific post Reply with quote
Well TDC can be found when Both intake and exhaust are LOOSE on #1 or #6 , ya can remove the timing window on the PUMP , I have never run into one that the timing marks were NOT on the flywheel and removal of the timing plate on the right side of the bell housing there SHOULD BE a POINTER . One can pull the injector on #1 and with care and a piece of SOFT wire or a long probe with a dial indicator you can get dead on . You also can loosen #1 injection line as you turn it over and look for fuel at the injector then ya can FIGURE out about where your at taken account timing advance . GESSSS Come on guys ya want to play MECHANICS then use your heads .
Joshbraman
PostPosted: Sun May 09, 2021 6:13 am    Post subject: Re: 886 358 diesel setting valves tsc marks cant find Reply to specific post Reply with quote
Thanks for all the help. We got it set. Ive never seen a tractor with no marks on the pulley either. Its odd. There are marks on the smaller part of the pulley towards the block but the arrow is all the way up top to the big part of the pulley. We. Just turned it over a few times till we got what you described with cylinder 1 then 6. We have a book on it but it gave no description on how to set TDC. Im assuming thats because it should be obvious how to do it. Weve worked on a lot of IH tractors, including a 826 that we did a injector pump on, but I ve never seen one with no time marks. Just goes to show you run across a lot different things if you work on enough of these tractors.
