Re: Indicator light
Tony in SD
PostPosted: Sat May 08, 2021 2:54 pm    Post subject: Re: Indicator light Reply to specific post Reply with quote
Im not aware of indicator lights on any N that I have seen.
HCooke
PostPosted: Sat May 08, 2021 3:30 pm    Post subject: Re: Indicator light Reply to specific post Reply with quote
9Ns had an 'ignition on' indicator light. Google wiring diagrams by JMOR'.
Btzj02
PostPosted: Sun May 09, 2021 5:24 am    Post subject: Re: Indicator light Reply to specific post Reply with quote
CVPost-Tony in SD wrote:
(quoted from post at 15:54:46 05/08/21) Im not aware of indicator lights on any N that I have seen.
A little reminder that the key is on can't hurt!
Caryc
PostPosted: Sun May 09, 2021 9:07 am    Post subject: Re: Indicator light Reply to specific post Reply with quote
Btzj02 wrote:
(quoted from post at 06:24:10 05/09/21)
Unless you leave the key on. Mr. Green
Smokeonthewater
PostPosted: Sun May 09, 2021 9:22 am    Post subject: Re: Indicator light Reply to specific post Reply with quote
personally, if I wanted to add a reminder that the key was on, I would use a buzzer hooked to an oil pressure switch....
Btzj02
PostPosted: Sun May 09, 2021 10:37 am    Post subject: Re: Indicator light Reply to specific post Reply with quote
Smokeonthewater wrote:
(quoted from post at 10:22:39 05/09/21) personally, if I wanted to add a reminder that the key was on, I would use a buzzer hooked to an oil pressure switch....
I try to live by the KISS principle. This light is simply on if the ignition circuit has voltage. Now a buzzer for low oil pressure?... That has possibilities!
Smokeonthewater
PostPosted: Sun May 09, 2021 10:52 am    Post subject: Re: Indicator light Reply to specific post Reply with quote
Btzj02 wrote:
(quoted from post at 14:37:27 05/09/21)
Fairly common on marine engines... generally tied into temp switch too
Buzzer serves the same purpose as the light plus an oil warning....
If you like the light and want an oil warning, simply ground the light through an oil pressure switch.... then it would go off when the engine started as long as oil pressure came up
Caryc
PostPosted: Sun May 09, 2021 11:19 am    Post subject: Re: Indicator light Reply to specific post Reply with quote
CVPost-HCooke wrote:
(quoted from post at 16:30:28 05/08/21) 9Ns had an 'ignition on' indicator light. Google wiring diagrams by JMOR'.
If someone's really worried about it. How about a long necklace with the key on it. Then if you tried to get off the tractor with the ignition on, it would strangle you. Mr. Green
That's on heck of a reminder.
Smokeonthewater
PostPosted: Sun May 09, 2021 12:09 pm    Post subject: Re: Indicator light Reply to specific post Reply with quote
Caryc wrote:
(quoted from post at 15:19:46 05/09/21)
I like it!
Btzj02
PostPosted: Sun May 09, 2021 4:20 pm    Post subject: Re: Indicator light Reply to specific post Reply with quote
.[/quote]
I like it![/quote]
Like that chord you clip to your shirt when on the tread mill! I supposed you would start hanging clothes on the Old Ford too, just like the treadmill in my basement!
Smokeonthewater
PostPosted: Sun May 09, 2021 4:36 pm    Post subject: Re: Indicator light Reply to specific post Reply with quote
Just don't clip it to the pto Shocked Shocked Shocked
hunkydory
PostPosted: Mon May 10, 2021 3:05 pm    Post subject: Re: Indicator light Reply to specific post Reply with quote
I had an extra hole in the dash and did the same thing with a green LED.
Tim PloughNman Daley
PostPosted: Sat May 15, 2021 5:49 am    Post subject: Re: Indicator light Reply to specific post Reply with quote
Yes, Tony, they did. The first 25000 units or so had a dash Ignition 'ON' lamp -see pic. It was mounted underneath the AMMETER and used a standard #63 bayonet-style 6V bulb, the same as the TAURUS and DUOLAMP Taillights.
EARLY FORD-FERGUSON 9N w/DASH LAMP:
Tim Daley(MI)
PostPosted: Sat May 15, 2021 5:53 am    Post subject: Re: Indicator light Reply to specific post Reply with quote
What wiring are you looking for? All the MPC's have parts and sketches. If you have a 9N dash lamp, you would also have a special wiring harness as well as pushbutton starter mounted on the upper LH dash panel. Need help, email me.
Tim Daley(MI)
