Need Cub grill
Goto page 1, 2  Next
old
PostPosted: Wed May 12, 2021 2:11 pm    Post subject: Need Cub grill Reply to specific post Reply with quote
So I have the hood on my cub now but it is missing the grill and maybe the dog legs if that isn't part of the grill. Anybody have a grill I could get??
Charlie M
PostPosted: Wed May 12, 2021 3:33 pm    Post subject: Re: Need Cub grill Reply to specific post Reply with quote
I think the grills changed over the years so you should probably state a year. My cub is a 47 and I know sometime a few years later the grill changed at least once.
old
PostPosted: Wed May 12, 2021 3:53 pm    Post subject: Re: Need Cub grill Reply to specific post Reply with quote
Mine is a 1947 with no hyds
grandpa Love
PostPosted: Wed May 12, 2021 4:09 pm    Post subject: Re: Need Cub grill Reply to specific post Reply with quote
I got one. Will look for dog legs, may have them.
old
PostPosted: Wed May 12, 2021 4:47 pm    Post subject: Re: Need Cub grill Reply to specific post Reply with quote
As it sits right now the hood sits down on top of the radiator and I don't think that is a good thing since it could cause the radiator to spring a leak
BarnyardEngineering
PostPosted: Thu May 13, 2021 3:53 am    Post subject: Re: Need Cub grill Reply to specific post Reply with quote
The hood should have ears that bolt to the radiator supports, holding it a little bit above the radiator.
grandpa Love
PostPosted: Thu May 13, 2021 4:05 am    Post subject: Re: Need Cub grill Reply to specific post Reply with quote
I think the dog legs is all that hold it
up.........
DeltaSteve
PostPosted: Thu May 13, 2021 6:11 am    Post subject: Re: Need Cub grill Reply to specific post Reply with quote
Pretty sure I have a grill out in the shed. You can have it for the shipping. However,it may be pricey comeing from Western Colorado to Missouri.Call if interested.nine7o-4!7-1!7eight
old
PostPosted: Thu May 13, 2021 7:54 am    Post subject: Re: Need Cub grill Reply to specific post Reply with quote
I thought that also till I put the hood back on and the bolt holes in the radiator area do not even come close to lining up to holes in the hood
Jim Becker
PostPosted: Thu May 13, 2021 9:45 am    Post subject: Re: Need Cub grill Reply to specific post Reply with quote
CVPost-old wrote:
(quoted from post at 10:54:49 05/13/21) I thought that also till I put the hood back on and the bolt holes in the radiator area do not even come close to lining up to holes in the hood
Then you have something either bent or badly misassembled. What Barnyard said is correct.
old
PostPosted: Thu May 13, 2021 10:02 am    Post subject: Re: Need Cub grill Reply to specific post Reply with quote
There are pieces missing or the dogleg part is part of the grill. The hood cannot bolt directly to the radiator support and even when you look at the hood you can see where something is missing since it has an area that should have some sort of sheet metal over it
grandpa Love
PostPosted: Thu May 13, 2021 11:38 am    Post subject: Re: Need Cub grill Reply to specific post Reply with quote
I say wrong. Got 6 cubs. No such bolts
on any of them.
old
PostPosted: Thu May 13, 2021 12:23 pm    Post subject: Re: Need Cub grill Reply to specific post Reply with quote
Yes the triangle sort of piece and grill is what I need. I don't have either side or the grill. But at least now I have a better idea of what they look like. One problem I do have is on the left side the lower stove bolt is broken off in the casting and sticks out about a 1/4 inch but will not come out. I am thinking I may need to weld a washer and nut on it to get it out
muleboss
PostPosted: Thu May 13, 2021 3:40 pm    Post subject: Re: Need Cub grill Reply to specific post Reply with quote
[quote="CVPost-old"](reply to post at 16:23:26 05/13/21) [/quote
Sorry I have many more cubs and yes there should be a small strap in side the hood that bolts to the radiator. ]
John M
PostPosted: Thu May 13, 2021 5:13 pm    Post subject: Re: Need Cub grill Reply to specific post Reply with quote
Jim and BYE are right. I found a pic, but I cant post it because it links to a competing sight. Google Farmall Cub hood supports, them images. Should be the first image, second one shows a diagram, and where they attach.
Goto page 1, 2  Next
Page 1 of 2
