Busted 9N / 2N Hyd pump . . .
Bruce(OR)
PostPosted: Wed May 12, 2021 3:49 pm    Post subject: Busted 9N / 2N Hyd pump . . . Reply to specific post Reply with quote
Fella posted this over on the Fergy board.
I haven't played with my pump in a long time and have forgotten too much.
The TO-20 pump being the Ferguson System found on the front badges of the 9N and 2N.
Any ideas?
I posted a week or so ago about my TO20 hydraulic not working, I was using the rear blade and then, nothing, I have worked on it
several times, and had the pump out, the valves out and cleaned, they looked good, the pump is working, I checked the tube taking the oil
to the cylinder, it doesnt leak, I did not take the relief valve apart because its preset. I sprayed it down with penetrating oil and blew
everything out, I have had this tractor since 66 and hate to set it aside, but am out of ideas, I am not young anymore and crawling under
it to take it apart is not easy anymore, But I guess I will put it away and forget about it, Thanks for reading my sob story
Hobo,NC
PostPosted: Thu May 13, 2021 3:24 am    Post subject: Re: Busted 9N / 2N Hyd pump . . . Reply to specific post Reply with quote
There is a long spring on the lift linkage that attaches from the linkage to the lift cylinder I have seen them break is it intact... JMOR has a pix of it... If its broke the lift will not work : (
https://forums.yesterdaystractors.com/viewtopic.php?t=823852&highlight=jim
Bruce(OR)
PostPosted: Thu May 13, 2021 6:26 am    Post subject: Re: Busted 9N / 2N Hyd pump . . . Reply to specific post Reply with quote
Thank you for that. I sent it onward and we shall see what, if anything, develops
John Deere D
PostPosted: Sat May 15, 2021 5:56 am    Post subject: Re: Busted 9N / 2N Hyd pump . . . Reply to specific post Reply with quote
Quote:
There is a long spring on the lift linkage that attaches from the linkage to the lift cylinder I have seen them break is it intact... If its broke the lift will not work : (
Bob..
