Jubilee Radiator and Shroud Colors
Del Huebner
PostPosted: Thu May 13, 2021 2:06 pm    Post subject: Jubilee Radiator and Shroud Colors Reply to specific post Reply with quote
Working on trying to bring back a Jubilee as close to original as I can. Would like to know if someone could tell me the colors of the radiator and
shroud? I am thinking either red or black but not sure. Thanks
JMOR
PostPosted: Thu May 13, 2021 3:15 pm    Post subject: Re: Jubilee Radiator and Shroud Colors Reply to specific post Reply with quote
CVPost-Del Huebner wrote:
(quoted from post at 18:06:18 05/13/21) Working on trying to bring back a Jubilee as close to original as I can. Would like to know if someone could tell me the colors of the radiator and
'almost' certain red shroud & black radiator.
Royse
PostPosted: Thu May 13, 2021 7:27 pm    Post subject: Re: Jubilee Radiator and Shroud Colors Reply to specific post Reply with quote
JMOR wrote:
(quoted from post at 19:15:15 05/13/21)
I don't know for sure either, but I think JMOR is right.
The radiator was painted with high heat black radiator paint. Still available.
The shroud, I believe, was painted with the same red paint as the body.
Sure wish I could find anything that told me for sure, but I have not.
I've painted at least four Jubes now, and painted them all that way.
This photo from John Smith's history site.
showcrop
PostPosted: Fri May 14, 2021 3:21 am    Post subject: Re: Jubilee Radiator and Shroud Colors Reply to specific post Reply with quote
I have an advertising catalog from 1958 that used actual photographs. I have gone through it carefully a few times but the lighting is not adequate to tell the color of the shroud. I agree with the others however that the radiator should be black and the shroud red. My apologies to JMOR.
steve in ok
PostPosted: Fri May 14, 2021 4:43 am    Post subject: Re: Jubilee Radiator and Shroud Colors Reply to specific post Reply with quote
If you search on you tube for the advertisement video of the jubilee you may be able to see the shroud color and maybe get an idea of radiator color.
JMOR
PostPosted: Fri May 14, 2021 6:27 am    Post subject: Re: Jubilee Radiator and Shroud Colors Reply to specific post Reply with quote
steve in ok wrote:
(quoted from post at 08:43:00 05/14/21) If you search on you tube for the advertisement video of the jubilee you may be able to see the shroud color and maybe get an idea of radiator color.
steve in OK is correct. In the 31 minutes of "The New Ford Tractor" (Golden Jubilee) there are few opportunities to see the shroud due to camera angles & lighting, but here is one screen shot from the video. Also, a bit of a surprise to me is that the coil mounting bracket is black, as I expected cadmium plated with no paint.
michford
PostPosted: Fri May 14, 2021 9:11 am    Post subject: Re: Jubilee Radiator and Shroud Colors Reply to specific post Reply with quote
Wonder what the cable running down the tube from the air cleaner to carb is in the screen shot?
JMOR
PostPosted: Fri May 14, 2021 9:14 am    Post subject: Re: Jubilee Radiator and Shroud Colors Reply to specific post Reply with quote
CVPost-michford wrote:
(quoted from post at 13:11:59 05/14/21) Wonder what the cable running down the tube from the air cleaner to carb is in the screen shot?
fuel line from gas tank.
michford
PostPosted: Fri May 14, 2021 10:03 am    Post subject: Re: Jubilee Radiator and Shroud Colors Reply to specific post Reply with quote
Interesting. I didn't think that was where the fuel line was routed on Jubilee and NAA tractors.
JMOR
PostPosted: Fri May 14, 2021 10:11 am    Post subject: Re: Jubilee Radiator and Shroud Colors Reply to specific post Reply with quote
(quoted from post at 14:03:44 05/14/21) Interesting. I didn't think that was where the fuel line was routed on Jubilee and NAA tractors.
Well, it is, then as Ford went fromNAA to hundred series they made the big mistake of routing the fuel line between manifold and head, probably the hottest place around the engine! Rolling Eyes
Del Huebner
PostPosted: Fri May 14, 2021 1:39 pm    Post subject: Re: Jubilee Radiator and Shroud Colors Reply to specific post Reply with quote
Thank You All for the help. Will go with the black radiator and red shroud. I think it will look real good.
