Fat fingers and tiny tractors
thdrduck
PostPosted: Thu May 13, 2021 2:52 pm    Post subject: Fat fingers and tiny tractors Reply to specific post Reply with quote
Is there really a more frustrating job than installing valve spring keepers on a Farmall Cub with old fat fingers?
old
PostPosted: Thu May 13, 2021 3:29 pm    Post subject: Re: Fat fingers and tiny tractors Reply to specific post Reply with quote
Grease comes in handy when doing that. I had a couple of stuck valves on my cub not long ago and had to pull them to free them up so yep BTDT
DeltaRed
Putting keepers on an upside down valve
in a flathead engine.
Absent Minded Farmer
PostPosted: Thu May 13, 2021 5:54 pm    Post subject: Re: Fat fingers and tiny tractors Reply to specific post Reply with quote
Squeezing my hand, that doesn't bend well anymore, in between the headlight & hood on a 560 to screw the fastener in that never wants to line up with
the hole.
Mike
wore out
PostPosted: Thu May 13, 2021 10:06 pm    Post subject: Re: Fat fingers and tiny tractors Reply to specific post Reply with quote
CVPost-DeltaRed wrote:
(quoted from post at 16:29:12 05/13/21) Putting keepers on an upside down valve
In case you've forgotten that's EXACTLY what the O.P. is dealing with.
As a creative solution, that's not a very large machine and the engine (IF removed) or possibly the whole tractor could be inverted to make the job similar to working on an OHV engine. (IMHO!)
grandpa Love
PostPosted: Fri May 14, 2021 3:32 am    Post subject: Re: Fat fingers and tiny tractors Reply to specific post Reply with quote
I wouldn't know.....that's my wife's
job!
Bob 7337
PostPosted: Fri May 14, 2021 5:54 pm    Post subject: Re: Fat fingers and tiny tractors Reply to specific post Reply with quote
loosen head lite and turn it a little. problem solved!
thdrduck
PostPosted: Sat May 15, 2021 10:11 am    Post subject: Re: Fat fingers and tiny tractors Reply to specific post Reply with quote
Had to stop for a bit, spring sprung and one of those little bast___s went flying. Looked for over an hour before I found it.
If it wasn't bad enough, add those damn hyd lines into the equation. Will be really happy when this job is done.
old
PostPosted: Sat May 15, 2021 10:53 am    Post subject: Re: Fat fingers and tiny tractors Reply to specific post Reply with quote
I placed a couple magnets close the where the valve I was work on at the time so if I dropped the keeper good chance the magnet would catch it. It worked I did drop one and it landed on the magnet
thdrduck
PostPosted: Sat May 15, 2021 11:26 am    Post subject: Re: Fat fingers and tiny tractors Reply to specific post Reply with quote
CVPost-old wrote:
(quoted from post at 19:53:00 05/15/21) I placed a couple magnets close the where the valve I was work on at the time so if I dropped the keeper good chance the magnet would catch it. It worked I did drop one and it landed on the magnet
Pro active, I like it. I used paper towels to plug the holes in the block and used a magnet to find the missing keeper. I have some strong magnets I could use to catch them should (and I'm sure it will) try to pull a hide and seek thing again. Thanks Old.
old
PostPosted: Sat May 15, 2021 11:46 am    Post subject: Re: Fat fingers and tiny tractors Reply to specific post Reply with quote
Put put rags in the holes that the keepers could have fell in if the magnet had not caught them. Sure would be easy to work on if the engine was upside down. LOL
thdrduck
PostPosted: Sat May 15, 2021 4:03 pm    Post subject: Re: Fat fingers and tiny tractors Reply to specific post Reply with quote
CVPost-old wrote:
(quoted from post at 20:46:13 05/15/21) Put put rags in the holes that the keepers could have fell in if the magnet had not caught them. Sure would be easy to work on if the engine was upside down. LOL
Mine almost was I was do ------. Twisted Evil
