changing 6volt system to 12 volts on Ferguson
MF165
PostPosted: Fri May 28, 2021 10:11 am    Post subject: changing 6volt system to 12 volts on Ferguson Reply to specific post Reply with quote
is there a diagram of how to convert 6v to 12 system?
miner09
PostPosted: Fri May 28, 2021 12:33 pm    Post subject: Re: changing 6volt system to 12 volts on Ferguson Reply to specific post Reply with quote
Replace coil with 12 volt that has internal resistor is all you change
and 12 volt battery. You can use 6 volt coil and add inline resistor in
wire on + side coil. Best to get 12 coil with internal resister.
Tom H.
PostPosted: Fri May 28, 2021 12:37 pm    Post subject: Re: changing 6volt system to 12 volts on Ferguson Reply to specific post Reply with quote
You will also need to change your charging system. Single wire 12v alternator easy to install plus switch to negative grounding
Jim L WA
PostPosted: Fri May 28, 2021 12:39 pm    Post subject: Re: changing 6volt system to 12 volts on Ferguson Reply to specific post Reply with quote
Do a search on jmor pictogram. select the one that fits your tractor the best.
Charles in Aus.
PostPosted: Sat May 29, 2021 2:07 am    Post subject: Re: changing 6volt system to 12 volts on Ferguson Reply to specific post Reply with quote
Starter remains the same and will work in the same direction as always woth either polarity . Keep starting cycles short , 4 or 5 seconds at a time or else the starter will overheat . The cost of a new one will make your eyes water .
