getting the brake band out
Goto page Previous  1, 2
steve(ill)
PostPosted: Tue Jun 01, 2021 1:41 pm    Post subject: Re: getting the brake band out Reply to specific post Reply with quote
on the 4 rim bolts.. When you take them off you will see 2 of them are just BOLTS.. TWO of them are CAMS,, you twist the bolt head to rotate it 180 degrees and rotate the LOCK outward to the rim.. HOLD and tighten the nut... Its a CAM design to wedge the blocks to the rim.
steve(ill)
PostPosted: Tue Jun 01, 2021 1:48 pm    Post subject: Re: getting the brake band out Reply to specific post Reply with quote
To reinstall, put the two straight bolts and clamps onto the hub at 2 and 11 oclock position... put a floor jack on the drawbar and lower the hub 1 inch below the rim height.. Roll the tire over and set around the hub, where you want it to set......... jack up the floor jack and let the rim hang on the two stationary clamps.... now you can install the two CAMS at 5 and 8 oclock positons.. ROTATE the bolts so the push OUT ( there is an arrow on the head)... and tighten the nuts.
Robert12345
PostPosted: Tue Jun 01, 2021 5:10 pm    Post subject: Re: getting the brake band out Reply to specific post Reply with quote
SO IF I LEAVE THE TWO BOLTS IN I CAN ROTATE THE TWO CAMS SO THEY NO LONGER GRAB THE RIM THEN TAKE OUT THE TWO BOLTS AND REMOVE THE LESS HEAVY TIRE AND RIM AND DEAL WITH THE WEIGHTED HUB BY ITSELF?, IVE SENT FOR MY MANUALS BUT WHAY DID ALLIS CHALMERSS MAKE THE WHEEL ATTACHMENT IN THIS WAY, WHY CAMSS? INSEAD OF 4 BOLTS? THANKS FOR YOUR PATIENCE, THE ONE THING THAT KEEPS ME FROM DIVING IN IS THE CRIBBING AND HOISTS NEEDED TO REMOVE THE CAST IRON DRIVE SECTION. IM GOING TO TO PUT OUT FEELERS TO SEE IF I CAN FIND SOMEONE IN WILL COUNTY, OR GRUNDY COUNTY ILLINOIS WHO WOULD DO THE BRAKES AND HAD WORKED ON THIS MODEL BEFORE.
steve(ill)
PostPosted: Wed Jun 02, 2021 1:41 pm    Post subject: Re: getting the brake band out Reply to specific post Reply with quote
yep... rotate the two cam bolts to loosen, then take them out.. the other two can stay on the HUB.... there are some aftermarket rims that have a LOOP welded to the rim to stick the bolt thru and no cams. They used them on some International tractors.. Dont know why ALLIS did the cam.
old
PostPosted: Wed Jun 02, 2021 2:42 pm    Post subject: Re: getting the brake band out Reply to specific post Reply with quote
Rim from the Farmall A and B will bolt right on. I know because I have done so in the past and with out looking to be sure I think one of my Cs have one on it
Robert12345
PostPosted: Wed Jun 02, 2021 5:58 pm    Post subject: Re: getting the brake band out Reply to specific post Reply with quote
im being overly cautious dont wnt the tire and rim comeing off til im ready.
old
PostPosted: Wed Jun 02, 2021 6:33 pm    Post subject: Re: getting the brake band out Reply to specific post Reply with quote
Position the 2 non cam mounts at the top and the 2 cam ones at the bottom. That way it will hang on the two top ones till you either rotate the center or use a pry bar to lift it off. BTDT many times
Robert12345
PostPosted: Thu Jun 03, 2021 11:56 am    Post subject: Re: getting the brake band out Reply to specific post Reply with quote
thanks im now going to ask the railroad switch engine crew if i can take a couple old ties for cribbing ive got your picture of how to chain it up. can you give me some insight of whats in the part im takeing off, my brake drum is in there and slides back and forth, key way is missing. i thought i would see a bolt hole when the drum slid out of sight, supposedly ther is a bolt you put in from the bottom to hold the drum? i didnt see a bolt with the drum in the catalogue/ what if its broke off can i tack weld it. any one know the size of the bolt. going to borrow an engine hoist that dhould handle it.the piece not the trsctor
steve(ill)
PostPosted: Thu Jun 03, 2021 3:04 pm    Post subject: Re: getting the brake band out Reply to specific post Reply with quote
Keep the good tire on the ground. Block under the center case ( differential / transmission).. you can also put a block under the square tube sticking out both sides that the brake pedals bolt to. Take the tire and rim off the hub. If the hub is loose on the shaft ( wobble), then take the BIG nut off and remove the hub also. If the hub is TOO TIGHT to move, leave it on.. TAke out the 4 nuts holding the FINAL DRIVE CASE ( left or right) to the DIFFERENTIAL/ TRANSMISSION case.. Rig up the engine puller or overhead chainfall to the Final Case.. bump the case outward with a hammer and it will slide off. The TOP SHAFT that has the brake drum on it is splined and slides INTO the Differential. When the case is off, you will be able to reach inside and move the brake drum.. The shaft has a KEY WAY in it.. The brake drum has a KEY WAY in it. There is a key that holds the two together. There is a square head bolt in the edge of the brake drum that you screw in to put the drum in a bind so it will not slide sideways off the key.. The bolt is probably a 3/8 NC thread. You tighten it thru the 1 inch hole in the underside of the final drive case.
Robert12345
PostPosted: Thu Jun 03, 2021 5:59 pm    Post subject: Re: getting the brake band out Reply to specific post Reply with quote
ill let you know how i made out thanks for help
Page 2 of 2
