NH hayliner 68 problem
Eboor1995
PostPosted: Thu Jun 10, 2021 6:40 pm    Post subject: NH hayliner 68 problem Reply to specific post Reply with quote
I have a new holland hayliner 68 that is tying both knots but one knot is coming untied when the bale starts to come out of the chamber and gets pressure applied to the knot. Any ideas on how to fix that? Made 45 bales today but broke another 50
DanielW
PostPosted: Fri Jun 11, 2021 3:45 am    Post subject: Re: NH hayliner 68 problem Reply to specific post Reply with quote
Very likely the knives are just getting a little dull, or the twine's not getting
stripped off the bill hook completely. See this post:
Knotter Trouble
DeltaSteve
PostPosted: Fri Jun 11, 2021 6:31 am    Post subject: Re: NH hayliner 68 problem Reply to specific post Reply with quote
Just like I told the guy above. Order a manual! It will have trouble shooting guides with pictures.That old baler will have issues. All
balers do,especially older ones.So you need a book,so you can fix it yourself and not have to wait on us for an answer. We cant see it(or the
knot),so any answer is just a guess. Less then 40 bucks.
gbs
PostPosted: Sun Jun 13, 2021 5:23 pm    Post subject: Re: NH hayliner 68 problem Reply to specific post Reply with quote
check check your knifes for sharpness, check the bearing on the bill hook, if o.k. tighten the tension on the bill hook a little, sounds like it is
cutting twine short on one side or the twine is slipping out of the bill hook not tying the knot enough to hold until the bale expands and finishes
tighten the knot, compare the gap of the bill hook to the other side it could be a little wide even though it is closing causing it not to hold the
twine.
showcrop
PostPosted: Mon Jun 14, 2021 3:25 am    Post subject: Re: NH hayliner 68 problem Reply to specific post Reply with quote
I checked out an old New Holland Saturday that was doing that. There was almost no twine tension. You need to cut yourself a break and go step by step through all the checks and adjustments.
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
