Ford 2N/9N Hydraulic Pump Control Valve
rick199
PostPosted: Fri Jun 11, 2021 11:01 am    Post subject: Ford 2N/9N Hydraulic Pump Control Valve Reply to specific post Reply with quote
I couldn't find a search button, so at the risk of being redundant here is a new question and help topic:
Does anyone have a suggestion or trick to install the Control Valve on the wishbone of a 2N? This is in the hydraulic housing attached to the hyd pump. I overhauled all the parts on top lid and bottom including the pump. While attempting to reinstall the top lid I'm having difficulty spreading the wishbone from the cylinder to attach the Hydraulic Pump Control Valve from the pump. I can't quite get my hands down through the inspection plates to spread the wishbone enough. Any help will be greatly appreciated. akcmret92@gmail.com.
JMOR
PostPosted: Fri Jun 11, 2021 12:21 pm    Post subject: Re: Ford 2N/9N Hydraulic Pump Control Valve Reply to specific post Reply with quote
rick199 wrote:
(quoted from post at 15:01:55 06/11/21) I couldn't find a search button, so at the risk of being redundant here is a new question and help topic:
Cut a stick slightly longer than T on valve, then twist and wedge it between arms to spread, then reverse to install T.
rick199
PostPosted: Fri Jun 11, 2021 9:15 pm    Post subject: Re: Ford 2N/9N Hydraulic Pump Control Valve Reply to specific post Reply with quote
JMOR wrote:
(quoted from post at 13:21:24 06/11/21)
Thanks I'll try that.
boler76
PostPosted: Sat Jun 12, 2021 4:18 am    Post subject: Re: Ford 2N/9N Hydraulic Pump Control Valve Reply to specific post Reply with quote
I just did one recently using a screwdriver through the drain hole with a light shining in the
side manhole
