How do you mark blind holes for drilling
Goto page 1, 2  Next
old
PostPosted: Fri Jun 11, 2021 12:57 pm    Post subject: How do you mark blind holes for drilling Reply to specific post Reply with quote
So I am making a couple doglegs for my 1947 Cub. The 2 bottom holes are blind hole and while the first one was close I'd like to get them right on. There 1/4 inch bolt hole in the casting.
grandpa Love
PostPosted: Fri Jun 11, 2021 1:26 pm    Post subject: Re: How do you mark blind holes for drilling Reply to specific post Reply with quote
Put a screw in the hole. Smear lip stick on screw head. Lol works every time
GordoSD
PostPosted: Fri Jun 11, 2021 1:37 pm    Post subject: Re: How do you mark blind holes for drilling Reply to specific post Reply with quote
I am surprised that Smear lipstick on the screw head didn't get poofed. LOL
markct
PostPosted: Fri Jun 11, 2021 1:44 pm    Post subject: Re: How do you mark blind holes for drilling Reply to specific post Reply with quote
Spotting punches, for threaded holes they make ones that look like a setscrew with a point, for non threaded they have a round pilot and shoulder and a point
550Doug
PostPosted: Fri Jun 11, 2021 1:56 pm    Post subject: Re: How do you mark blind holes for drilling Reply to specific post Reply with quote
CVPost-grandpa Love wrote:
(quoted from post at 17:26:56 06/11/21) Put a screw in the hole. Smear lip stick on screw head. Lol works every time
I have a tube of toothpaste in my toolbox just for that job.
old
PostPosted: Fri Jun 11, 2021 2:05 pm    Post subject: Re: How do you mark blind holes for drilling Reply to specific post Reply with quote
I sort of did that. I put a stove bolt in the hole and sprayed it with paint then put the dog leg in place and it marked it as I needed. If my stupid cell phone would work you would have a 3rd picture of the doglegs. I just finished up the 2nd one and the next project will be the grill. Still not sure how I cam going to make the curved bends on the sides for the grill. Don't think Thing for making bends would work since it is made to make a true 90 degree bend
Mike(NEOhio)
PostPosted: Fri Jun 11, 2021 2:20 pm    Post subject: Re: How do you mark blind holes for drilling Reply to specific post Reply with quote
Transfer screws. As markct said. Grind a sharp point on a Gr 8 set screw. If you can't get to it from the other side of the hole file or saw flats so you can get it in and out with pliers. Gr 8s will be hard enough for a couple of uses. Leave the points about 1/16 above the surface and strike the part to mark locations.
steve_in_mo
PostPosted: Fri Jun 11, 2021 2:45 pm    Post subject: Re: How do you mark blind holes for drilling Reply to specific post Reply with quote
Do you have a piece of PVC pipe about that size?
old
PostPosted: Fri Jun 11, 2021 2:49 pm    Post subject: Re: How do you mark blind holes for drilling Reply to specific post Reply with quote
Not that I know of but I think I have some steel pipe about that size
caterpillar guy
PostPosted: Fri Jun 11, 2021 2:57 pm    Post subject: Re: How do you mark blind holes for drilling Reply to specific post Reply with quote
I use paper or cardboard and tap the hole gently to make a hole in the paper/cardboard screw in a bolt then do the next usually going across from the first to get the most distance so it will not be Multiplying the err. And keep putting bolts in as I go. Then check for true then lay on piece you want the holes in punch and drill. Transfer punches work good for the marks to drillthe holes.
Stephen Newell
PostPosted: Fri Jun 11, 2021 4:17 pm    Post subject: Re: How do you mark blind holes for drilling Reply to specific post Reply with quote
I would be inclined to set up stops on the drill press instead of marking them. When doing multiple parts its the best way to get them uniform.
grizz02
PostPosted: Fri Jun 11, 2021 4:29 pm    Post subject: Re: How do you mark blind holes for drilling Reply to specific post Reply with quote
Buy a set of transfer punches 40.00 on line
4520BW
PostPosted: Fri Jun 11, 2021 5:22 pm    Post subject: Re: How do you mark blind holes for drilling Reply to specific post Reply with quote
I guess the metoo movement people are too busy worrying gender identity and who is on the syrup bottle to look at tractor website...for now
TimV
PostPosted: Fri Jun 11, 2021 6:52 pm    Post subject: Re: How do you mark blind holes for drilling Reply to specific post Reply with quote
Under 10 bucks for a set of 6 1/4-20 transfer screws on Amazon. For a couple uses, just turning down the head of a bolt into a point works fine--I'm still using ones I made 20 years ago like that for the occasional time I need an oddball size that I don't have store-bought transfer screws for. You're just trying to make a mark, which you can then make deeper with an actual center punch if necessary.
transfer screws
rustred
PostPosted: Fri Jun 11, 2021 7:38 pm    Post subject: Re: How do you mark blind holes for drilling Reply to specific post Reply with quote
yep, yep, thats the ticket. as old says... btdt ! lol.
Goto page 1, 2  Next
Page 1 of 2
