Modification on pull behind sprayer
Goto page 1, 2  Next
Geo-TH,In
PostPosted: Sat Jun 12, 2021 5:44 am    Post subject: Modification on pull behind sprayer Reply to specific post Reply with quote
After testing different pressures and speed I'm ready to spray driveway.
A mist comes in contact with the aluminum
Then drips off. Let you know in a week or two how it works.
bc
PostPosted: Sat Jun 12, 2021 6:16 am    Post subject: Re: Modification on pull behind sprayer Reply to specific post Reply with quote
According to my calculations, at 11 miles per hour you will achieve lift off.
Steve in VA
PostPosted: Sat Jun 12, 2021 6:25 am    Post subject: Re: Modification on pull behind sprayer Reply to specific post Reply with quote
Wow. Now see i thought it was ground
effect to keep traction on the sprayer.
Geo-TH,In
PostPosted: Sat Jun 12, 2021 6:37 am    Post subject: Re: Modification on pull behind sprayer Reply to specific post Reply with quote
At 88 mph I can go back to the future and
see a younger handsome guy....my son when
he was born.
bc
PostPosted: Sat Jun 12, 2021 6:53 am    Post subject: Re: Modification on pull behind sprayer Reply to specific post Reply with quote
CVPost-Steve in VA wrote:
(quoted from post at 09:25:15 06/12/21) Wow. Now see i thought it was ground
Just need a spoiler on the front to keep the front end down and a wheelie bar on the back of the tractor and it will win a few races. lol (just having fun George)
Goose
PostPosted: Sat Jun 12, 2021 7:13 am    Post subject: Re: Modification on pull behind sprayer Reply to specific post Reply with quote
Why that shield over the boom?
I've worked with a lot of sprayers from that size to field sprayers and I've never seen that before.
GordoSD
PostPosted: Sat Jun 12, 2021 7:14 am    Post subject: Re: Modification on pull behind sprayer Reply to specific post Reply with quote
You don't need that boom so high. Old baler belts are most often used up here for shielding. Put about 10 inch strip ahead of the boom hanging down, and wrap around the ends toward the back. Keeping the wind from blowin your spray away is the goal.
johnofnewhaven
PostPosted: Sat Jun 12, 2021 7:15 am    Post subject: Re: Modification on pull behind sprayer Reply to specific post Reply with quote
Reminds me of the Flying Nun.
funky_g00
PostPosted: Sat Jun 12, 2021 7:29 am    Post subject: Re: Modification on pull behind sprayer Reply to specific post Reply with quote
While I agree your MOD will help with drift and overspray. I also have to ask why you have the boom so high. I assume its to allow clearance for some obstacle in your yard? I would think if the sprayer is for driveway use only, setting the boom 6-12 inches off the ground would accomplish the same thing.
grizz02
PostPosted: Sat Jun 12, 2021 8:18 am    Post subject: Re: Modification on pull behind sprayer Reply to specific post Reply with quote
Not sure why the spray bar is so high , this is my 25 gal sprayer I got from craigslist for 40.00 it will spray 10ft wide
Geo-TH,In
PostPosted: Sat Jun 12, 2021 9:09 am    Post subject: Re: Modification on pull behind sprayer Reply to specific post Reply with quote
I can adjust spray bar. After many adjustments, I used water and tested spray pattern on pole barn floor.
This height gave me the results I wanted.
Geo-TH,In
PostPosted: Sat Jun 12, 2021 9:21 am    Post subject: Re: Modification on pull behind sprayer Reply to specific post Reply with quote
I adjusted to get best spray pattern with least pressure and least fine mist.
GordoSD
PostPosted: Sat Jun 12, 2021 11:25 am    Post subject: Re: Modification on pull behind sprayer Reply to specific post Reply with quote
Give it up guys. Everyone is wrong and Geo is right. At least he is consistent.
caterpillar guy
PostPosted: Sat Jun 12, 2021 11:58 am    Post subject: Re: Modification on pull behind sprayer Reply to specific post Reply with quote
If the nozzles are 20 inches apart 20 inches high is the proper setting for coverage and difrt per Teejet's pattern for an 80 degree nozzle.
bc
PostPosted: Sat Jun 12, 2021 1:44 pm    Post subject: Re: Modification on pull behind sprayer Reply to specific post Reply with quote
Grizz, what kind of nozzles and how many are you using to get 10 feet wide? Looks like you are using the same pump that comes with it just like mine. Thanks.
Goto page 1, 2  Next
Page 1 of 2
