4630 destroker screw
Ikelandon
PostPosted: Mon Jun 14, 2021 2:38 am    Post subject: 4630 destroker screw Reply to specific post Reply with quote
The destroker screw on my 4630 is pouring oil out the top of the pump. I blew the line going to the cooler yesterday changed it then this started. Is the pump bad or could it be something simple?
tim s
PostPosted: Mon Jun 14, 2021 3:32 am    Post subject: Re: 4630 destroker screw Reply to specific post Reply with quote
Just an O-ring leaking, but it's a nasty job to change on the tractor..the spring and stroke valve stem will fall out...and of course oil will be running down your arm pit..
Hay maker2
PostPosted: Mon Jun 14, 2021 3:51 am    Post subject: Re: 4630 destroker screw Reply to specific post Reply with quote
There are a couple of O-rings for the manual destroke screw that's on the top of the pump. Its a simple change.
Keep in mind that there are 2 different destroke screw that were used based upon the pump.
Is the screw back all the way out so it is against its seat? If not it will leak.
tim s
PostPosted: Mon Jun 14, 2021 3:43 pm    Post subject: Re: 4630 destroker screw Reply to specific post Reply with quote
I was thinking he was talking about the stroke adjusting screw,,on the bottom..
