JD A 49, DTLX 71 Carb Issue
Goto page 1, 2  Next
JD2CylFan
PostPosted: Fri Jun 11, 2021 11:41 am    Post subject: JD A 49, DTLX 71 Carb Issue Reply to specific post Reply with quote
I am new to working on this tractor and have a question. I don't seem to be getting fuel in the bowl of the carb or to the cylinders. I have fuel going into the carb at the fuel strainer assembly, but when I turn the bowl drain I don't get anything to come out? Is there anything that I can do without removing the carb to possibly correct this issue? And I assume that the gravity feed is enough to get fuel to the bowl? I also cranked the engine over with full choke to see if I could get fuel to the bowl, but that did not work either...Any and all help will be greatly appreciated..
Dan in Ohio
PostPosted: Fri Jun 11, 2021 11:50 am    Post subject: Re: JD A 49, DTLX 71 Carb Issue Reply to specific post Reply with quote
The fuel inlet on the carb has a wire mesh filter unless it has been removed which is highly likely. Start there and let us
know what you find.
JD2CylFan
PostPosted: Fri Jun 11, 2021 11:56 am    Post subject: Re: JD A 49, DTLX 71 Carb Issue Reply to specific post Reply with quote
Yes it has the wire mesh filter...
Dan in Ohio
PostPosted: Fri Jun 11, 2021 12:00 pm    Post subject: Re: JD A 49, DTLX 71 Carb Issue Reply to specific post Reply with quote
Reread your post, not sure if you have cleaned the screen at the carb inlet. If so try dropping the bowl and spraying the needle valve with carb cleaner, you may just have a stuck needle valve.
JD2CylFan
PostPosted: Fri Jun 11, 2021 12:05 pm    Post subject: Re: JD A 49, DTLX 71 Carb Issue Reply to specific post Reply with quote
Ok, will do...To remove the bowl, I just unscrew the big bolt at the bottom of the bowl, and it will let loose? Anything to watch for when removing or assembling? And can I clean the needle seat after removing the cap with the screen and spraying down towards the needle?
Dan in Ohio
PostPosted: Fri Jun 11, 2021 12:22 pm    Post subject: Re: JD A 49, DTLX 71 Carb Issue Reply to specific post Reply with quote
Make absolutely sure you are turning the bowl nut the correct direction, very easy to muck up those threads. Yes, you should
be able to flush with carb cleaner from the inlet and from underneath the bowl. You may have to tap the bowl with the handle
end of a screw driver to get it to come loose.
JD2CylFan
PostPosted: Fri Jun 11, 2021 1:10 pm    Post subject: Re: JD A 49, DTLX 71 Carb Issue Reply to specific post Reply with quote
k, give that a try and let you know... Thanks for your assistance, thus far.
Dan in Ohio
PostPosted: Fri Jun 11, 2021 1:23 pm    Post subject: Re: JD A 49, DTLX 71 Carb Issue Reply to specific post Reply with quote
Your post JD A 49 caught my eye. Here is my 49 A which rarely gets out of the barn anymore.
coonie minnie
PostPosted: Fri Jun 11, 2021 2:07 pm    Post subject: Re: JD A 49, DTLX 71 Carb Issue Reply to specific post Reply with quote
Nice tractors!
JD2CylFan
PostPosted: Sat Jun 12, 2021 11:39 am    Post subject: Re: JD A 49, DTLX 71 Carb Issue Reply to specific post Reply with quote
Well removed the bowl of the carb and found the float stuck and some rust in the bowl, cleaned out and put back together. Now I have fuel coming into the bowl, as I opened the drain valve and fuel came out. However, now i need a gasket for the strainer cover, as there was not much of a gasket on there and it leaks fuel from around the strainer cover... Will try to find a gasket or if anyone knows of a good place to get one. After I get the gasket, I should be ready to try to start it up.
JD2CylFan
PostPosted: Sat Jun 12, 2021 11:40 am    Post subject: Re: JD A 49, DTLX 71 Carb Issue Reply to specific post Reply with quote
Yes your A looks sharp!!!!
JD2CylFan
PostPosted: Sat Jun 12, 2021 11:42 am    Post subject: Re: JD A 49, DTLX 71 Carb Issue Reply to specific post Reply with quote
Here is a photo of mine that I am working on.
This post was edited by JD2CylFan on 06/12/2021 at 12:56 pm.
swindave
PostPosted: Sat Jun 12, 2021 1:19 pm    Post subject: Re: JD A 49, DTLX 71 Carb Issue Reply to specific post Reply with quote
thats a nice looking a,
NoDakInMN
PostPosted: Sun Jun 13, 2021 7:26 am    Post subject: Re: JD A 49, DTLX 71 Carb Issue Reply to specific post Reply with quote
JD2CylFan wrote:
(quoted from post at 14:39:51 06/12/21) Well removed the bowl of the carb and found the float stuck and some rust in the bowl, cleaned out and put back together. Now I have fuel coming into the bowl, as I opened the drain valve and fuel came out. However, now i need a gasket for the strainer cover, as there was not much of a gasket on there and it leaks fuel from around the strainer cover... Will try to find a gasket or if anyone knows of a good place to get one. After I get the gasket, I should be ready to try to start it up.
Roberts Carburetor Repair should have what you need.
JD2CylFan
PostPosted: Sun Jun 13, 2021 3:52 pm    Post subject: Re: JD A 49, DTLX 71 Carb Issue Reply to specific post Reply with quote
NoDakInMN wrote:
(quoted from post at 11:26:59 06/13/21)
@NoDakInMN Thanks for the referral. But I think I am going to try to clean up the metal surface real good and see if I can get the current gasket to make a seal, if not I will order one up.
Its been about a year since it was running, any tips on getting it to fire?
Goto page 1, 2  Next
Page 1 of 2
