1520 flared plastic tubing
OregonAaron
PostPosted: Tue Jun 15, 2021 6:46 am    Post subject: 1520 flared plastic tubing Reply to specific post Reply with quote
So, on my 1520 there is a piece of approx 1/4" plastic tubing that is flared on both ends with a plastic nut that runs from the reserve hydraulic reservoir (behind gas tank) down to the hydraulic pump. I broke one of these brittle plastic nuts and now am in search of a replacement. I have flared my own tubing before for automotive brake lines and such, but not plastic tubing. Is this a special pre-made part? Can I flare my own? I would imagine flaring plastic would require some heat?
Tx Jim
PostPosted: Tue Jun 15, 2021 7:32 am    Post subject: Re: 1520 flared plastic tubing Reply to specific post Reply with quote
I've never attempted to flair plastic line. Line part # is AT20960 @ $25.24
Jim.ME
PostPosted: Tue Jun 15, 2021 8:18 am    Post subject: Re: 1520 flared plastic tubing Reply to specific post Reply with quote
Tx Jim wrote:
(quoted from post at 11:32:19 06/15/21)
I've ended up buying those lines from JD to get a good seal, patch jobs don't hold up in the long run.
OregonAaron
PostPosted: Tue Jun 15, 2021 9:30 am    Post subject: Re: 1520 flared plastic tubing Reply to specific post Reply with quote
I ordered one. John deere sure is proud of their parts! $25 for 3' of 1/4 tubing and 2 plastic nuts. Oh well, that's the way it is.
fdt860
PostPosted: Tue Jun 15, 2021 12:05 pm    Post subject: Re: 1520 flared plastic tubing Reply to specific post Reply with quote
OregonAaron wrote:
(quoted from post at 10:30:13 06/15/21) I ordered one. John deere sure is proud of their parts! $25 for 3' of 1/4 tubing and 2 plastic nuts. Oh well, that's the way it is.
Deere claimed 1.7B$ revenues on the first quarter of this year while blaming on the flu for having to increase parts price. Who know what their revenues would have been without it....
tomstractorsandtoys
PostPosted: Tue Jun 15, 2021 4:02 pm    Post subject: Re: 1520 flared plastic tubing Reply to specific post Reply with quote
It is very easy to flare plastic tube. Take a metal flaring tool and heat it with a torch and touch the plastic to it untill you get the flare you want. I do this all the time on 3020 and 4020's on the hyd pump bleed off line. Deere gives you one way to long. I have even bought new tube at auto parts and used the old fittings to make my own. Tom
OregonAaron
PostPosted: Tue Jun 15, 2021 4:05 pm    Post subject: Re: 1520 flared plastic tubing Reply to specific post Reply with quote
CVPost-tomstractorsandtoy wrote:
(quoted from post at 17:02:56 06/15/21) It is very easy to flare plastic tube. Take a metal flaring tool and heat it with a torch and touch the plastic to it untill you get the flare you want. I do this all the time on 3020 and 4020's on the hyd pump bleed off line. Deere gives you one way to long. I have even bought new tube at auto parts and used the old fittings to make my own. Tom
Well, Tom, guess it's too late! I will have to DIY it next time. Thank you for the help!
M-MAN
PostPosted: Tue Jun 15, 2021 4:09 pm    Post subject: Re: 1520 flared plastic tubing Reply to specific post Reply with quote
Used to have oil line fittings like that
at plant I worked at. I just held a
lighter under the line a few seconds and
pushed it up onto the flare and
tightened the nut. All you need is to
soften it a little just like you would a
plumbing pipe.
P I Pete
PostPosted: Wed Jun 16, 2021 7:33 am    Post subject: Re: 1520 flared plastic tubing Reply to specific post Reply with quote
SIL has a gator needed rear axel shafts as boots and u joints were out Deere wanted
over $300.00 each, his daughter found them on net just over $100.00 for both.
Pete
