impllements for a non hydraulic b
Robert12345
PostPosted: Mon Jun 14, 2021 1:00 pm    Post subject: impllements for a non hydraulic b Reply to specific post Reply with quote
other than pull a plow or wagon or even with a plow a b without hydraulics uses a spring aid to the operataor in lifting a plow or belly mower, have i got that right?, a bush hog for a b would have a third wheel on the ground at all times, any body got a thread to implements made for a b. mine has two ears with one inch holes on each side of radiatgor welded to frame so maybe for a front blade? got to figurte out how to send pics.
YTSupport
Site Admin
PostPosted: Tue Jun 15, 2021 5:50 am    Post subject: Re: impllements for a non hydraulic b Reply to specific post Reply with quote
I've observed several expedients people implemented to get around this, such as a front blade having arms that pivoted from the finals and was raised and lowered with a automotive steering gear and side mounted steering wheel on a 38 B. Another example was a 3 point with a hand operated pump on an IB. The front blade arrangement was fairly effective as there was clearance enough to work with under the front axle. The hand pump wasn't as it couldn't handle the weight of any significant implement.
Certainly tow-behind implements designed for ATVs would work well. Only problem there is the cost. Those tend to be self-supporting with multiple wheels.
d13series1
PostPosted: Tue Jun 15, 2021 10:14 am    Post subject: Re: impllements for a non hydraulic b Reply to specific post Reply with quote
Have a front blade that dries off the finals, and yes it has a helper spring.
Nordic
PostPosted: Tue Jun 15, 2021 1:02 pm    Post subject: Re: impllements for a non hydraulic b Reply to specific post Reply with quote
Anywhere you can mount an electric winch you can lift all kinds of implements. Last fall I put on a heavy duty snow blade on my WF tractor w/o hydraulics. It works excellent, I thought maybe a 42 amp alternator would struggle to keep up but not at all. The battery seems to be fully charged when I park. My winch is 5000 lb., more power than many hydraulic set ups.
Robert12345
PostPosted: Tue Jun 15, 2021 1:07 pm    Post subject: Re: impllements for a non hydraulic b Reply to specific post Reply with quote
you wouldnt have the plans or a photo of how you did it
Robert12345
PostPosted: Tue Jun 15, 2021 1:09 pm    Post subject: Re: impllements for a non hydraulic b Reply to specific post Reply with quote
was it made for the tractor and does it have a model no, or all self design?
Robert12345
PostPosted: Tue Jun 15, 2021 1:11 pm    Post subject: Re: impllements for a non hydraulic b Reply to specific post Reply with quote
appreciate the reply
Nordic
PostPosted: Tue Jun 15, 2021 9:21 pm    Post subject: Re: impllements for a non hydraulic b Reply to specific post Reply with quote
Hi Robert, I'll be glad to send you some pictures if you give me a bit of time. I'm probably a bit rusty with putting pictures on here but will give it a try. As I said earlier it's an Allis Chalmers WF that I put the winch lift on but I also have a B model with a snow blade, the push frame attaches to the final drive housings and it has a hydraulic lift on it. The pump is a Charlene style pump that runs off the PTO and it works like music on the B models, my '48 B doesn't have the Allis hyd. pump, this Charlene pump is more efficient. I'll try to send you pictures of the blade set up on the B as well. The lift on my B could just as easily be done with an electric winch as well. I bought my B with the hydraulic set up all on it. The B is excellent for moderate snow pushing, it is very quick with shifting gears, the blade lifts fast and the whole unit manoeuvres very quickly. Having said all that... I don't even know if you have snow where you live LOL.
Jim.ME
PostPosted: Thu Jun 17, 2021 2:34 am    Post subject: Re: impllements for a non hydraulic b Reply to specific post Reply with quote
Most any implement, appropriately sized of course, can be used with a B. Drawbar pull with mechanical lift ones are the ones you will be looking for without adding hydraulics to your tractor. Also something like a rotary brush cutter will have two wheels on the unit and a mechanical height adjustment. Using a single wheel with a drawbar pull would be prone to tipping side to side. A caster type single tail wheel would be on a 3 point hitch type unit, where the two draft links provide the means to keep them level.
If you insert "allischalmers" in place of "blank" in the address below it in your browser and search it should take you to a discussion on another site with a number of pictures of Bs, with equipment people have hooked to theirs. Some with and without hydraulics.
https://www.blank.com/forum/show-your-b-implements_topic146070.html
Robert12345
PostPosted: Thu Jun 17, 2021 6:25 pm    Post subject: Re: impllements for a non hydraulic b Reply to specific post Reply with quote
looking forward to pics, can send to my e mail if that is easier rfp5114@yahoo.com, got plenty of snows most years
Nordic
PostPosted: Thu Jun 17, 2021 9:28 pm    Post subject: Re: impllements for a non hydraulic b Reply to specific post Reply with quote
CVPost-Robert12345 wrote:
(quoted from post at 18:25:43 06/17/21) looking forward to pics, can send to my e mail if that is easier rfp5114@yahoo.com, got plenty of snows most years
I trust you got the pictures I emailed you.
