Tractors with chains on mowers....
banjoman09
PostPosted: Thu Jun 17, 2021 3:38 pm    Post subject: Tractors with chains on mowers.... Reply to specific post Reply with quote
So you guys with 2N-8N-9N's and your rotary mowers how do you install your chains for depth control? Do you put the slotted
brackets on the tractor-on top- or on the mower? Thanks
Btzj02
PostPosted: Thu Jun 17, 2021 4:10 pm    Post subject: Re: Tractors with chains on mowers.... Reply to specific post Reply with quote
I put the slotted brackets on either side of the top 3 point connection. Easier to adjust the chains as needed.
Den N Ms
PostPosted: Thu Jun 17, 2021 4:11 pm    Post subject: Re: Tractors with chains on mowers.... Reply to specific post Reply with quote
banjoman09, On the top link pin.
Rich.Fl
PostPosted: Thu Jun 17, 2021 5:25 pm    Post subject: Re: Tractors with chains on mowers.... Reply to specific post Reply with quote
Yes, on the top. I also use a 5/8 grade 8 bolt with large washers and two nuts rather than the standard pin.
banjoman09
PostPosted: Thu Jun 17, 2021 6:06 pm    Post subject: Re: Tractors with chains on mowers.... Reply to specific post Reply with quote
ok and thanks much Smile
banjoman09
sounds good and will do !
Tim PloughNman Daley
PostPosted: Fri Jun 18, 2021 2:43 am    Post subject: Re: Tractors with chains on mowers.... Reply to specific post Reply with quote
The 8N has POSITION CONTROL and does not need limiter chains on a mower. Of course if hydraulics are weak and in need if rebuild, it may not sustain the position very well. The 9N & 2N with just Draft Control only may require limiter chains to maintain set height. You can also invest in a ZANE THANG position control device, now copied and sold by Red Rock and others. Zane Sherman passed away a few years ago and the family no longer has any dealings with Ford Tractors nor his devices.
Tim Daley(MI)
Caryc
PostPosted: Fri Jun 18, 2021 7:28 am    Post subject: Re: Tractors with chains on mowers.... Reply to specific post Reply with quote
CVPost-Tim PloughNman Dal wrote:
(quoted from post at 03:43:00 06/18/21) The 8N has POSITION CONTROL and does not need limiter chains on a mower. Of course if hydraulics are weak and in need if rebuild, it may not sustain the position very well. The 9N & 2N with just Draft Control only may require limiter chains to maintain set height. You can also invest in a ZANE THANG position control device, now copied and sold by Red Rock and others. Zane Sherman passed away a few years ago and the family no longer has any dealings with Ford Tractors nor his devices.
Tim Daley(MI)
My 8N has very good working position control and I still use limiter chains on my mower. Why have the position control working for hours at a time while mowing? I use the chains simply to give my hydraulics a rest. I just put the control lever all the way down and let the mower hang on the chains.
Caryc
PostPosted: Fri Jun 18, 2021 7:35 am    Post subject: Re: Tractors with chains on mowers.... Reply to specific post Reply with quote
CVPost-banjoman09 wrote:
(quoted from post at 16:38:35 06/17/21) So you guys with 2N-8N-9N's and your rotary mowers how do you install your chains for depth control? Do you put the slotted
Here's how the chains are hooked up on my 8N. The lynch pins you see in the chains are a good way to make minute adjustments. Just put a pin through two links. They are also a good way to hold up dangling chain ends.
R Geiger
PostPosted: Fri Jun 18, 2021 11:11 am    Post subject: Re: Tractors with chains on mowers.... Reply to specific post Reply with quote
Caryc wrote:
(quoted from post at 09:35:10 06/18/21)
Agree, I do the same with my 8n when mowing.
Mad Farmer
PostPosted: Sat Jun 19, 2021 9:54 am    Post subject: Re: Tractors with chains on mowers.... Reply to specific post Reply with quote
9N , I use top link and never remove the chain adjuster tabs.
