CASE CK BACKHOE PIN AND BUSHING
AmeriKen
PostPosted: Sat Jun 16, 2007 5:29 pm    Post subject: CASE CK BACKHOE PIN AND BUSHING Reply to specific post Reply with quote
I'm in the midst of replacing lower pin and bushing on the swing tower of my CASE CK backhoe. As best I can determine it is a model 32 backhoe. Can the pin/bolt, nut, washers, and ball bushing be acquired as a kit or do each part have to be ordered?
Here are the part numbers individually:
Pin: D37451
NUT: 25-1324 (1-1/2" - 12 NF)
SPACERS: D26991
BALL PIVOT BUSHING: D23601
Are these parts available from aftermarket dealers?
Anonymous
PostPosted: Mon Jun 18, 2007 5:47 am    Post subject: Re: CASE CK BACKHOE PIN AND BUSHING Reply to specific post Reply with quote
About 3/4 of all the pins and bushing are available aftermarket - but a few must come from Case. And those will cost twice what they are worth since Cases knows you cannot get them elsewhere. I just put all new ones in my 32 hoe. Biggest problem was that big self-centering bearing. With mine, the bore in the casting was worn out and egg shaped.
Anonymous
PostPosted: Mon Jun 18, 2007 6:38 am    Post subject: Re: CASE CK BACKHOE PIN AND BUSHING Reply to specific post Reply with quote
AmeriKen,
The D37451 pin is a part number for the Model #33 hoe. You will probably have to get those parts from Case
jdemaris,
Part of the problem with that lower tower pivot is the D30760 pin on the #32 is not long enough and eats half way through the upper support. If you change to the D37451 pin and special D36476 washer used on the #33 hoe you get full purchase at the upper support. I'd be curious to hear how you repaired the hogged out holes....weld & align bore...bush...or??
