ALLIS CHALMERS HD5G
Thomas Smith
PostPosted: Sat Jun 16, 2007 10:46 pm    Post subject: ALLIS CHALMERS HD5G Reply to specific post Reply with quote
Need help on a HD5G with a 2-71 detroit motor. Motor will start up and run fine but when you go to put in in gear (under a load) the motor dies. What are some possible issues or things that need to be checked out. The throttle control and governs seem to be messed up............ don't know any help would be greatly appreciated.
Anonymous
PostPosted: Sun Jun 17, 2007 2:08 am    Post subject: Re: ALLIS CHALMERS HD5G Reply to specific post Reply with quote
Do you know if he smoke black that could be the air cleaner probleme or fuel filter or a bad injector.
El Toro
PostPosted: Sun Jun 17, 2007 6:30 am    Post subject: Re: ALLIS CHALMERS HD5G Reply to specific post Reply with quote
You need to make sure you have clean fuel and new fuel filters. Then bleed the fuel system at the secondary fuel filter. That should be on the pressure side of the pump so it will purge out all the air. The Detroits are good about bleeding the air from the system. The military used lots of Detroit diesel engines. Hal
