Carburetor linkage rod busted on my TO30
K.Campbell
PostPosted: Sun Apr 24, 2022 11:30 am    Post subject: Carburetor linkage rod busted on my TO30 Reply to specific post Reply with quote
I need recommendations on where to get the rod that goes from my carburetor to the governor. Mine was seized up. I soaked the rusted end in kroil oil for two days, it was still stuck fast. Then I heated up the turnbuckle and attempted to turn it after getting it hot. It broke! Im in the middle of getting this to30 running, I had my carb soaking overnight now Im going to have to wait to find a rod with a turnbuckle on it, to see if my carb cleaning was successful.
Bruce(OR)
PostPosted: Sun Apr 24, 2022 2:50 pm    Post subject: Re: Carburetor linkage rod busted on my TO30 Reply to specific post Reply with quote
Carb to governor rod.
Made from Unobtanium for the land of Obsoleteum.
I have considered getting some of those fabbed up.
For the need of a horse, the kingdom was lost.
I understand.
Fleabay showing anything?
K.Campbell
PostPosted: Sun Apr 24, 2022 3:36 pm    Post subject: Re: Carburetor linkage rod busted on my TO30 Reply to specific post Reply with quote
no but fakebook marketplace has one possibly. I contacted t he guy and he gave me his number. Ill call him tomorrow. Bruce, you should for sure fab some of those up.. Id buy a couple just to have them.
Steve@Advance
PostPosted: Sun Apr 24, 2022 4:02 pm    Post subject: Re: Carburetor linkage rod busted on my TO30 Reply to specific post Reply with quote
McMaster Carr has the clevis end.
The rod can be made from a piece of round stock.
Be sure to get the length in range, it is critical.
McMaster Carr
K.Campbell
PostPosted: Sun Apr 24, 2022 4:07 pm    Post subject: Re: Carburetor linkage rod busted on my TO30 Reply to specific post Reply with quote
Awsome! Do you by chance know what size I need to order? Lol
Steve@Advance
PostPosted: Sun Apr 24, 2022 4:28 pm    Post subject: Re: Carburetor linkage rod busted on my TO30 Reply to specific post Reply with quote
I think it's 1/4 28, but I'm working from memory.
Best compare it to your old one, take some measurements.
K.Campbell
PostPosted: Sun Apr 24, 2022 4:54 pm    Post subject: Re: Carburetor linkage rod busted on my TO30 Reply to specific post Reply with quote
I will thanks!
pomester
PostPosted: Sun Apr 24, 2022 6:06 pm    Post subject: Re: Carburetor linkage rod busted on my TO30 Reply to specific post Reply with quote
Not sure how much of a purist you are, but I've been replacing the carb/governor rods on my Fergusons with ball joints. Use the same McMaster-Carr link and search 'oil-embedded ball joint linkages' - you want (2) 1/4"-28 female right hand thread. That and manufacture a 9-3/8" length of 1/4" steel rod with 1.25" of threads on each end, a couple of jam nuts, and you are in business. I do shorten the stud (bench grinder) that bolts to the carburetor bell crank to keep the installation clean, but you wouldn't have to.
The wear points at the governor lever, clevis end, throttle bell crank/rod end get sloppy after 70 years and the governor does not work as well as it might. The difference with this slop eliminated is immediately evident.
Frankly, better and a lot easier than reproducing an original with the way it attaches to the carburetor...
This post was edited by pomester on 04/24/2022 at 07:20 pm.
K.Campbell
PostPosted: Sun Apr 24, 2022 6:10 pm    Post subject: Re: Carburetor linkage rod busted on my TO30 Reply to specific post Reply with quote
I like that a lot thanks Ill call them tomorrow and order what I need. Thanks!!
