John Deere Sulky plow # 268
Duner Wi
PostPosted: Wed Jun 22, 2022 6:28 pm    Post subject: John Deere Sulky plow # 268 Reply to specific post Reply with quote
on main plow beam, might be model # 268 or part # of beam.
I would like to know how the tail wheel comes off.
Looks like you remove nuts from 4 -7/16 carriage bolts and outer hub should separate from wheel and inner hub. Mine has been sitting out doors unused for 75 years and wheel won't rotate. I got the other 2 wheels greased but this one is being difficult. Thank you.
David from Kansas
PostPosted: Wed Jun 22, 2022 6:34 pm    Post subject: Re: John Deere Sulky plow # 268 Reply to specific post Reply with quote
That is a beam number. If the tail wheel is like most of the older trailer plows by JD, You take the bolts out of the wheel and there is a sleeve with a pin through it that when removed, the hub will come off. Might be hard to see the pin as it will be covered with grease. That is the best I can remember. A pretty simple procedure.
Duner Wi
PostPosted: Wed Jun 22, 2022 7:20 pm    Post subject: Re: John Deere Sulky plow # 268 Reply to specific post Reply with quote
Here is photo of tail wheel.
Duner Wi
PostPosted: Thu Jun 23, 2022 6:53 pm    Post subject: Re: John Deere Sulky plow # 268 Reply to specific post Reply with quote
Here it is apart, just like you described.
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
