12V conversion Diode question
James Rader
PostPosted: Mon Jul 02, 2007 8:46 am    Post subject: 12V conversion Diode question Reply to specific post Reply with quote
Ok, I finally worked a day shift so that I could get to the electronics store and get the infamous 1N5408 diode. I have two questions...
1. When I install the diode does the printed band go toward or away from the altenator?
2. Is it ok to to put a layer of heat shrink over the diode and the solder joints?
I am hoping to finally get the wiring done tonight! Thanks for all your help!
James
GB in MT.
PostPosted: Mon Jul 02, 2007 8:59 am    Post subject: Re: 12V conversion Diode question Reply to specific post Reply with quote
Morning James;
The banded end goes toward the alt., Just like the diagram says in the box with the arrow pointing to it, on the sheet I sent ya.
Let me know if ya get fire tonight!!!
BTW, Yes you can and should cover the diode with shrink tube, just don't heat it up too much.
Gary
James Rader
PostPosted: Mon Jul 02, 2007 9:09 am    Post subject: Re: 12V conversion Diode question Reply to specific post Reply with quote
It says that on the diagram??? jeeesh, I've looked at that thing a blue million times... I don't have the diagram with me so I suppose that will be my excuse! Hee hee haw haw
I'll let everyone know in the morning if I get a chance to finish the project tonight and I'll email you specificly GB
James
GB in MT.
PostPosted: Mon Jul 02, 2007 9:13 am    Post subject: Re: 12V conversion Diode question Reply to specific post Reply with quote
Good man.!! Also if you want/need to, call me collect. I'll be here. I think I gave you my tele. #. Anytime!!!!!
Gary
James Rader
PostPosted: Mon Jul 02, 2007 9:27 am    Post subject: Re: 12V conversion Diode question Reply to specific post Reply with quote
Yep, got yer number and if anything goes weird I may give ya a jingle. No need for the collect call, we have one of those unlimited long distance telephone deals... everyone we know is long distance and it is the only way we can afford it. Cell phones don't work where we live so that isn't an option either.
James
Bob
PostPosted: Mon Jul 02, 2007 3:05 pm    Post subject: Re: 12V conversion Diode question Reply to specific post Reply with quote
AFAIK, I was the originator of suggesting to use the 1N5408 diode, 'cause it's more robust than some of the others that are recomended from time to time.
Have you seen this photo that I've posted here quite a number of times over the last few years?
The diode is shown "bare" for illustrative purposes, but I cover them in a double layer of heat shrink to preven the diode lead from flexing and breaking.
GB in MT.
PostPosted: Mon Jul 02, 2007 3:35 pm    Post subject: Re: 12V conversion Diode question Reply to specific post Reply with quote
Hi Bob;
Your diagram is the one I sent him for the re-wire of his "N". From what I can tell, that diagram is the best one out here being used!!!
I'm answering you, on this for him as he is probably working on it as we speak.
Thanks.
Gary
Hobo,NC
PostPosted: Mon Jul 02, 2007 4:52 pm    Post subject: Re: 12V conversion Diode question Reply to specific post Reply with quote
This izz a pix of one I installed 5 years or so ago, radio shack # 267-1144 3 amps 400PIV looks like it got a little hot sumwere along the line. Its solder at the connections Rosin core solder wif heat scrink are wuz, whut ya think, git'n a little green look'n,
dan hill
PostPosted: Tue Jul 03, 2007 1:38 am    Post subject: Re: 12V conversion Diode question Reply to specific post Reply with quote
I would replace that one soon.A 6 amp 1000 piv diode would be a better choice.
James Rader
PostPosted: Tue Jul 03, 2007 6:01 am    Post subject: Re: 12V conversion Diode question Reply to specific post Reply with quote
I installed the diode with the printed line toward the altenator, soldered the connection then used a crimp over that, double heat shrink then taped it onto the 10g wire heading back to the wire loom... If that diode gets loose from all that sumthin wrong!
Thanks guys
James
