Company Logo Auction Link (800) 853-2651
1952 Ferguson TO-30: Hi/Lo Transfer Case
JZ Tractors
PostPosted: Fri Jan 20, 2023 9:48 pm    Post subject: 1952 Ferguson TO-30: Hi/Lo Transfer Case Reply to specific post Reply with quote
I am restoring a 1952 Ferguson TO-30 and on the Hi/Lo transfer case, the bottom yoke keeps slipping off the control arm when we try to shift from hi to lo. Any suggestions on how to get the yokes and gears all back together inside the transfer case?
Thank you in advance for any help.
Bruce(OR)
PostPosted: Sat Jan 21, 2023 1:47 am    Post subject: Re: 1952 Ferguson TO-30: Hi/Lo Transfer Case Reply to specific post Reply with quote
Hi/Lo transfer case.
Yoke slipping off the arm, to me, at about 1.30 in the morning, sounds like your missing a pin.
Pictures might help.
Now is this transfer case in front of the transmission?, behind the transmission? or back at the PTO?
Handle on the right side, left side or top?
Then again at 1.30 AM the answer might be eluding me
Leroy
PostPosted: Wed Jan 25, 2023 9:50 am    Post subject: Re: 1952 Ferguson TO-30: Hi/Lo Transfer Case Reply to specific post Reply with quote
I think you should be calling a transmision instead of a
transfer case. That is what the factory called it and calling
it a transfer case could confuse people. I have both a 41 9N
and a 44 2N with just the overdrive gear in them as the ones
with the under drive gear were not yet avaible. Mine was put
in the 2N as soon as were avaible. Transfer means taking
power from one place to anouther, not changeing speed to what
it is hooked to.
jvin248
PostPosted: Thu Jan 26, 2023 2:41 pm    Post subject: Re: 1952 Ferguson TO-30: Hi/Lo Transfer Case Reply to specific post Reply with quote
Look up YouTube channel Bundy Bears as he show rebuilding a few fergies and may have what you need to see, or a model close enough you can work through.
