Author |
Message |
ricflair Regular
Posted: Sun Jan 22, 2023 7:22 am Post subject: john deere cam grind advice |
I am restoring a B, exhaust cam lobes are worn, would like to get it ground with a more effient profile.
Who should I have grind it? I hear good things about Bullet. Has anyone used extreme pulling parts? I think Denglers is out of business?
Thanks |
Back to top |
TVMAN Regular
Posted: Sun Jan 22, 2023 8:14 am Post subject: Re: john deere cam grind advice |
I have had 2 ground by josh Blackburn in Michigan done good job also It will have be degreed in
when installed thanks TVMAN |
Back to top |
ricflair Regular
Posted: Sun Jan 22, 2023 11:58 am Post subject: Re: john deere cam grind advice |
How do you degree? Do you have to have the gear holes slotted?
Thanks |
Back to top |
VicS Tractor Guru
Posted: Sun Jan 22, 2023 3:08 pm Post subject: Re: john deere cam grind advice |
It's to complicated to explain here. But
just ask Google. I have just done it 2
times, both times the cam grinder had it
dead on. You will get a spec sheet with
your reground cam. Might have to make a
offset key for your crank gear or get
another key way made in it. Or maybe
change the cam gear key, to a of set one.
Of course you need a.dial.indicator. They
really run good when everything is right.
Also I would find a good speed shop and
get everything balanced. Your flywheel is
probably off the most. |
Back to top |
ricflair Regular
Posted: Sun Jan 22, 2023 4:48 pm Post subject: Re: john deere cam grind advice |
Ok, sounds the same as auto. Thanks |
Back to top |
504 Tractor Guru
Posted: Thu Jan 26, 2023 5:21 pm Post subject: Re: john deere cam grind advice |
Off set keys have been around for years.Iskenderian(Isky Cams) is one manufacturer. |
Back to top |
6cylpower Regular
Posted: Fri Jan 27, 2023 7:26 am Post subject: Re: john deere cam grind advice |
No keys on a B cam, it bolts to the gear. Slot the holes if you want some advance. |
Back to top |
