Company Logo Auction Link (800) 853-2651
1 Wire Alternator
Goto page 1, 2  Next
super99
PostPosted: Tue Jan 24, 2023 2:44 pm    Post subject: 1 Wire Alternator Reply to specific post Reply with quote
Changing my 1850 from original 3 wire with regulator to a
1wire. Do I have to unhook the wires from the regulator or
can I just leave them hooked up?
There was a ground bolt on the new alternator, so I
hooked the old ground wire to it.
My 1550 had a 1 wire on it when I got it. No regulator and
the wires just hanging there. Not sure if I need to
disconnect wires from unused regulator or just leave it
alone. B Thanks,Chris
old
PostPosted: Tue Jan 24, 2023 3:03 pm    Post subject: Re: 1 Wire Alternator Reply to specific post Reply with quote
If it where me I would take the regulator off
Steve@Advance
PostPosted: Tue Jan 24, 2023 3:35 pm    Post subject: Re: 1 Wire Alternator Reply to specific post Reply with quote
Doesn't really matter as far as function.
It would look better is you took it off and clean up the wiring. One less thing to possibly ground out.
Bob Harvey
PostPosted: Tue Jan 24, 2023 4:49 pm    Post subject: Re: 1 Wire Alternator Reply to specific post Reply with quote
WHY ?
buickanddeere
PostPosted: Tue Jan 24, 2023 5:12 pm    Post subject: Re: 1 Wire Alternator Reply to specific post Reply with quote
CVPost-super99 wrote:
(quoted from post at 18:44:45 01/24/23) Changing my 1850 from original 3 wire with regulator to a
Why on earth install a one wire in place of a three wire ? Battery drain . Needs high rpm to start charging .
Janicholson
PostPosted: Tue Jan 24, 2023 5:43 pm    Post subject: Re: 1 Wire Alternator Reply to specific post Reply with quote
Agree with Steve and old! Jim
grandpa Love
PostPosted: Tue Jan 24, 2023 5:50 pm    Post subject: Re: 1 Wire Alternator Reply to specific post Reply with quote
I have a couple Cubs with Delco
one wire alternators, they start
start charging immediately, at an
idle...... I always unhook the
negative battery cable, when not
using, in case mice chew up
wires, short things out and start
a fire, hence no battery drain.
Traditional Farmer
PostPosted: Tue Jan 24, 2023 6:04 pm    Post subject: Re: 1 Wire Alternator Reply to specific post Reply with quote
I'm running about 10 1 wire alternators,they charge at start up and no battery drain.
SidS
PostPosted: Tue Jan 24, 2023 6:10 pm    Post subject: Re: 1 Wire Alternator Reply to specific post Reply with quote
If you want to remove the 10dn the 10si is ok but don't use a one wire.
JMOR
PostPosted: Tue Jan 24, 2023 7:32 pm    Post subject: Re: 1 Wire Alternator Reply to specific post Reply with quote
CVPost-Traditional Farmer wrote:
(quoted from post at 22:04:17 01/24/23) I'm running about 10 1 wire alternators,they charge at start up and no battery drain.
No battery drain , in your mind, but it is there. You can not prove that it isn't. Does it matter to you....obviously not. But don't try to fool the rest of the world with false hoods!
Dieseltech
PostPosted: Tue Jan 24, 2023 8:06 pm    Post subject: Re: 1 Wire Alternator Reply to specific post Reply with quote
I have three tractors with the one wire Delco, all three charge right away after starting. All three have a very slight current draw with engine off, not a problem IF they only set unused up to two or three weeks. Any longer and the ground cable is pulled off or the ground disconnect is turned off. My 560D has two batteries, and one time it set in the shed unused for four months, batteries were completely dead as I forgot to turn off the ground switch. They charged back up OK, and I remember to use the switch now.
JMOR
PostPosted: Tue Jan 24, 2023 8:15 pm    Post subject: Re: 1 Wire Alternator Reply to specific post Reply with quote
CVPost-Dieseltech wrote:
(quoted from post at 00:06:51 01/25/23) I have three tractors with the one wire Delco, all three charge right away after starting. All three have a very slight current draw with engine off, not a problem IF they only set unused up to two or three weeks. Any longer and the ground cable is pulled off or the ground disconnect is turned off. My 560D has two batteries, and one time it set in the shed unused for four months, batteries were completely dead as I forgot to turn off the ground switch. They charged back up OK, and I remember to use the switch now.
yep
Traditional Farmer
PostPosted: Wed Jan 25, 2023 12:31 am    Post subject: Re: 1 Wire Alternator Reply to specific post Reply with quote
I have a David Brown 780 with a 1 wire alternator it sits usually from Oct to May with the battery hooked up,it fires right up no problem to go rake hay.Really you should get some knowledge before calling me a liar,I'd love to for you to come by my place so I could school you on 1 wire alternators.
caterpillar guy
PostPosted: Wed Jan 25, 2023 2:27 am    Post subject: Re: 1 Wire Alternator Reply to specific post Reply with quote
I'm with Steve and Old it doen't matter for function just less to contend with later or cause problems. The battery wire could possibly be used from the regulator as long as it goes back to the amp gauge or volt meter and not through the old regulator same with the ground direct to ground.
Fixingfarmer
PostPosted: Wed Jan 25, 2023 4:09 am    Post subject: Re: 1 Wire Alternator Reply to specific post Reply with quote
Id wrap the other wires on the one your doing and the 1550 up with tape to protect them in case someone wants to put it back how it was. Not to mention there could be power there that could cause a spark if not unhooked farther back
Goto page 1, 2  Next
Page 1 of 2
