Author |
Message |
BarryfromIA Tractor Expert
Joined: 26 Mar 2006 Posts: 1917 Location: North West Iowa
Posted: Tue Jan 24, 2023 6:06 pm Post subject: Case Comfort King distributer drive parts |
I need an A 41414 coupling. This is the drive coupling on the bottom of the distributer and this is sheared off because of the tach drive siezed due to a lack of grease. This is about a 1966 model 730gas. |
Back to top |
J Hamilton Tractor Guru
Posted: Tue Jan 24, 2023 6:16 pm Post subject: Re: Case Comfort King distributer drive parts |
Might check with Brillman's or McDonald carb & ignition if you haven't already |
Back to top |
Posted: Tue Jan 24, 2023 7:52 pm Post subject: Re: Case Comfort King distributer drive parts |
Ok checked Brillman's and found nothing, I might check by part no tomorrow. |
Back to top |
r.w.b. Tractor Expert
Posted: Wed Jan 25, 2023 3:26 am Post subject: Re: Case Comfort King distributer drive parts |
try standard magnito
wood dale ill
800 624 6386
they might have what you need. they got lots of nos oem parts. 1
guy there cant think of his name is a distributer expert . |
Back to top |
Posted: Thu Jan 26, 2023 9:51 am Post subject: Re: Case Comfort King distributer drive parts |
I would be interested in a used distributer depending what's available and how complete.it is. |
Back to top |
stevieb49829 Long Time User
Posted: Sat Jan 28, 2023 7:21 pm Post subject: Re: Case Comfort King distributer drive parts |
Is it like a small Lovejoy coupler? Take a couple of measurements from it. I've got one off a Prestolite distributor that you can have if it will fit your needs. steve |
Back to top |
Joe (Wa) Tractor Expert
Posted: Sun Jan 29, 2023 9:56 am Post subject: Re: Case Comfort King distributer drive parts |
Back to top |
Posted: Sun Jan 29, 2023 10:35 am Post subject: Re: Case Comfort King distributer drive parts |
The prestolite measurements are 1/2 shaft, 1/8" roll pin. Overall about 3/4" + in length and a little less than an inch in diameter. I'd be happy to take care of the shipping and give you something for the part. |
Back to top |
Posted: Sun Jan 29, 2023 11:08 am Post subject: Re: Case Comfort King distributer drive parts |
Barry, here's a pic of what I have. It is about 1-9/16 long (without the shaft). One bore is right close to .500 +or- .002 (my caliper is in disagreement with my mic), and the other bore is .498 +or-. Role pins are 1/8. I can get it in the mail tomorrow, if it will fit your need. It was free to me, so free to you. steve
Back to top |
Posted: Sun Jan 29, 2023 11:11 am Post subject: Re: Case Comfort King distributer drive parts |
If Joe's diagram is what you have, I don't think mine will work. steve |
Back to top |
Posted: Sun Jan 29, 2023 1:23 pm Post subject: Re: Case Comfort King distributer drive parts |
Unless, of course, you want to file one down to make one half of mine fit yours. Is yours aluminum? If so, I think you could make one out of half of this one I have. I get about 3/4 inch from the end, to the edge of the pin hole where you'd need to cut it off, and an OD of just under an inch. If yours is a tab on either side of the bore, and not a piece running all the way across, you could file mine down to be just like yours. With both halves of mine, you'd have two times to try to screw it up??!!! Let me know if you want to try it. Last time I sent something this small, it cost about $8. And the parts are free. steve
Back to top |
Posted: Sun Jan 29, 2023 1:35 pm Post subject: Re: Case Comfort King distributer drive parts |
Try Jeff Schlemmer: He was very helpful. Built his own for an old Massey Harris 50, from one out of a Mini Cooper. jeff@advanceddistributors.com. |
Back to top |
Posted: Mon Jan 30, 2023 12:11 pm Post subject: Re: Case Comfort King distributer drive parts |
Thanks stevie for looking and thanks to Joe (wa)for the picture. My son is going to make one he says. |
Back to top |
Posted: Mon Jan 30, 2023 4:50 pm Post subject: Re: Case Comfort King distributer drive parts |
That would be a pretty simple project for a small lathe, and even better if you have a horizontal mill. Especially if it is aluminum. steve |
Back to top |
