8N won't charge battery
Charles Deviney
PostPosted: Tue Jul 03, 2007 4:16 pm    Post subject: 8N won't charge battery Reply to specific post Reply with quote
My 8N is 6V positive ground. Started fine last 2 years. Now, I can still mow 2+ hours but when I cut off tractor, it won't turn starter. Voltmeter shows only 5.8 - 6.0 volts at 1500 rpms, but had generator tested and shop says it's charging. If I put a battery charger on it for 10 minutes, tractor starts fine.Amp gauge never moves. Replaced voltage reg., no change. One odd thing, even when it was cranking fine, amp gauge moves to 10+ when headlights turned on.
Dunk
PostPosted: Tue Jul 03, 2007 4:23 pm    Post subject: Re: 8N won't charge battery Reply to specific post Reply with quote
My suspect is your battery.
How old is it?
They usually come in 2 year, 3 year, and 5 year models.
They pay engineers big bucks so that they fail really close to that.
Bruce (VA)
PostPosted: Tue Jul 03, 2007 4:24 pm    Post subject: Re: 8N won't charge battery Reply to specific post Reply with quote
How old is the battery & the cables? When is the last time you pulled all the cables & cleaned the connections? Some shops can still load test a 6v; most can't, so get a $5 hydrometer & check it yourself.
Charles Deviney
PostPosted: Tue Jul 03, 2007 4:30 pm    Post subject: Re: 8N won't charge battery Reply to specific post Reply with quote
Thanks. Battery and cables are about 2 years old. I haven't checked the connections since most everything on tractor was rebuilt then. Will check battery.
Charles Deviney
PostPosted: Tue Jul 03, 2007 4:34 pm    Post subject: Re: 8N won't charge battery Reply to specific post Reply with quote
It's 2 years old. If you crank tractor and open throttle and put voltmeter on battery it shows 5.8 to 6 volts only. I've been told that indicates a problem, but you say it may be the battery? That would sure be easy to fix. Thanks.
Paul Pa.
PostPosted: Tue Jul 03, 2007 4:50 pm    Post subject: Re: 8N won't charge battery Reply to specific post Reply with quote
Hi Charles, did you polarize the voltage regulator when you put the new one on? if not try that,good luck Paul
Charles Deviney
PostPosted: Tue Jul 03, 2007 4:54 pm    Post subject: Re: 8N won't charge battery Reply to specific post Reply with quote
Yes, the shop that sold me the regulator showed me how. Thanks for suggesting it, though.
j vickerd
PostPosted: Tue Jul 03, 2007 5:22 pm    Post subject: Re: 8N won't charge battery Reply to specific post Reply with quote
Hi
this may seem odd, but check out your starter relay,(solenoid) on the starter for good connections as well as your starter. could be after running it for 2 or 3 hours, in the hot sun the starter itself is heated to the point of tightening up inside. after 10 min. or so of cool down while charging it may loosen up enough to turn
Charles Deviney
PostPosted: Tue Jul 03, 2007 5:25 pm    Post subject: Re: 8N won't charge battery Reply to specific post Reply with quote
Thanks. I'll check this.
arthur ward
PostPosted: Tue Jul 03, 2007 5:29 pm    Post subject: Re: 8N won't charge battery Reply to specific post Reply with quote
charles, when you put the new battery in two years ago...did it charge then?
Jack-Illinois
PostPosted: Tue Jul 03, 2007 6:36 pm    Post subject: Re: 8N won't charge battery Reply to specific post Reply with quote
It seems that the posters have pretty much cover all the logical reasons. I think at this point I would take the wires (one at a time) loose at the voltage regulator and the generator and use your ohmeter to check continuity on each. If your generator has been checked and you installed a new voltage regulator it should show more voltage than you are getting at 1500 RPM. You might check the voltage across the battery while you have the charger on it just to make sure your voltmeter is OK. You could also check battery voltage and armature voltage at the generator when at the 1500 RPMs to make sure they are the same. Good luck - post back when you find it as I am curious.
Charles Deviney
PostPosted: Wed Jul 04, 2007 4:48 am    Post subject: Re: 8N won't charge battery Reply to specific post Reply with quote
Yes, it did. The tractor ran great for two years. Thanks for your help.
Charles Deviney
PostPosted: Wed Jul 04, 2007 4:51 am    Post subject: Re: 8N won't charge battery Reply to specific post Reply with quote
Thanks for your help. That seems like a real good idea. We'll try it.
Phil (NJ,Az,Sask)
PostPosted: Wed Jul 04, 2007 5:33 am    Post subject: Re: 8N won't charge battery Reply to specific post Reply with quote
Charles,
When headlights are turned ON you should read -10 Amps discharge if the tractor is "not" Running. If you are saying that the + 10 amps is when the tractor is running that would suggest that the regulator BAT connection is not connected to the LOAD side of the AMMETER.
I would suggest that you remove the BAT wire from the Regulator and Connect your EXTernal Charger to that wire. You then can use a volt meter to determine what connector/wire is Bad.
If you can Charge the battery and Ammeter shows charging via that wire your problem may be a bad ground @ the regulator
Hope this Helps,
Charles Deviney
PostPosted: Fri Jul 06, 2007 4:55 am    Post subject: Re: 8N won't charge battery Reply to specific post Reply with quote
Phil,
Thanks a lot. I'll try this.
