3-point
Roy H
PostPosted: Thu Jul 05, 2007 9:16 am    Post subject: 3-point Reply to specific post Reply with quote
When I engage the PTO anf let the clutch out I can pick up the 3-point. if I then push in the clutch the 3-point goes to the ground. I have replaced the 3 rings and honed the cylinder. Back check valve stuck in the pump or what? Any advise would help. DCR
Brian Bell
PostPosted: Thu Jul 05, 2007 11:15 am    Post subject: Re: 3-point Reply to specific post Reply with quote
Roy, looks like you have been overlooked so here is some info for you. See the link below. It was written by Zane Sherman. Should at least get you going.
Zanes Article
Joe(NYC)
PostPosted: Thu Jul 05, 2007 6:26 pm    Post subject: Re: 3-point Reply to specific post Reply with quote
If you have an N, then what you are describing is normal. The N does not have live hydraulics. I believe Mr Zane has a gizmo setup kit that will allow you to have live hydraulics.
dlplost
PostPosted: Thu Jul 05, 2007 9:08 pm    Post subject: Re: 3-point Reply to specific post Reply with quote
yes, it sounds like your safty valve is leaking.
Hitch should NOT drop just cause you push in the clutch, it should hold position.
