generator
oldtractor
PostPosted: Thu Jul 05, 2007 4:18 pm    Post subject: generator Reply to specific post Reply with quote
I just installed a used generator on my N. The ammeter reads "0" when I start and run the engine, then drops into negative territory when I turn on headlights. A multitester clipped to anything hot goes haywire even without grounding the other lead of the tester. What"s going on here?
Tom N MS
PostPosted: Thu Jul 05, 2007 4:20 pm    Post subject: Re: generator Reply to specific post Reply with quote
Got to use an analog meter. Digitals go crazy like that.
dan hill
PostPosted: Fri Jul 06, 2007 3:25 am    Post subject: Re: generator Reply to specific post Reply with quote
Ammeter says no charge, no need for a voltmeter.Always connect negative or ground lead of meter first.Old vtvm meters will swing up scale if you touch the probe on low ranges.
JoePilot
PostPosted: Fri Jul 06, 2007 9:01 am    Post subject: Re: generator Reply to specific post Reply with quote
Probably need to polarize the genny. I can never remember the specifics, but search for "polarize" in the archives and I'm sure you'll find lots of info. It is also in your repair manual. No manual? First link on the left border will let you buy one. Highly recommended.
Joe
