Engine problems
Jych4
PostPosted: Sun Jul 08, 2007 5:16 am    Post subject: Engine problems Reply to specific post Reply with quote
Iam very new to tractors, i purchased a 8n on ebay owner said it smokes and has smoked about 10 years. Anyways got it home to bush hog and noticed alot of what appears to be oil in the radiator, oil pressure is about 10 at idle warm and smokes and i took the plugs out and noticed oil on them too, my question is should i do a major rebuild or just a head job? Tractor runs good but probably not for long.
Thanks James
Bruce (VA)
PostPosted: Sun Jul 08, 2007 5:23 am    Post subject: Re: Engine problems Reply to specific post Reply with quote
Check the compression. Rings are probably worn. 10 lbs of oil pressure at a hot idle is not bad at all, meaning that the bearings might be ok. Not much you are going to do to the head that will stop it from smoking.
roger '40 9n
PostPosted: Sun Jul 08, 2007 5:38 am    Post subject: Re: Engine problems Reply to specific post Reply with quote
"Oil" in the water is usually just a head gasket.
Combustion by products get past the gasket and into the cooling water -- leaving "oil" on the water. It is not engine oil -- there are no oil passages in the head. Change your head gasket.
Be sure that you are using hot enuf sparkie plugs -- most folks here use Autolite 437 or Champion H12.
Roger in MichigaN
Dell (WA)
PostPosted: Sun Jul 08, 2007 8:23 am    Post subject: Re: Engine problems Reply to specific post Reply with quote
jych4..........iff'n its been smokin' fer 10yrs, don't worry about it for now.
Change yer sparkies to AutoLite 437's, check gap = 0.025" right outta the box. 437's are hotter and burn oil off'n them so they don't foul.
Oil floating in radiator water is semi-normal; it ain't oil. It may be combustion by-products due to semi-leaky headgasket, or could be waterpump lube additive, or type of anti-freeze. Your belchfire-V8 probably has floating oil too, but you don't see it 'cuz you can't look direct into the radiator water. You need to do the dreaded "compression test" to tell iff'n you have bad headgasket or bad rings. Ford specs: 90psi min (dry).........Dell
arthur ward
PostPosted: Sun Jul 08, 2007 8:53 am    Post subject: Re: Engine problems Reply to specific post Reply with quote
i am not a big believer in compression tests on an old engine, unless you are checking for a downed cylinder.
here is why: if you have worn rings then oil will get into cylinder and "seal" the rings during a compression test. thus it throws the reading off. i had 121 to 125 across the board on my 8n before rebuild. it just burned alot of oil. when i got my old parts back from the engine builder, i measured .030" gap between top ring and piston ring groove. it should be around .002". so, i had good compression but completely worn out rings. the bearings were perfect though. i also had around 6 - 7 oil pressure when hot. go to a 20w 50 oil and see what happens.
