Author |
Message |
crsutton81 Long Time User
Posted: Sun Nov 19, 2023 1:32 pm Post subject: JD 55 ABH plow |
When transporting this plow down the road, it tends to have the tail wheel violently shimmy to the point that the plow will unhook itself from the tractor if there is much speed involved. Has anyone experienced this or come up with a solution to curb the problem ? There is a plow day held locally every fall that we would drive this equipment to if we could quickly and safely get it there. |
Back to top |
Charlie M Tractor Guru
Posted: Sun Nov 19, 2023 1:50 pm Post subject: Re: JD 55 ABH plow |
I've never seen a trailer plow that wouldn't do that at higher speed. I've seen newer models with a bolt that locks the tail wheel so it can't wobble. I don't have a fix for the problem on a plow that doesn't have that feature. |
Back to top |
BlaineM Regular
Posted: Sun Nov 19, 2023 2:08 pm Post subject: Re: JD 55 ABH plow |
That feature should be on that plow. Both of my JD 55 ABH plows have it. |
Back to top |
Rich'sToys Tractor Guru
Posted: Sun Nov 19, 2023 2:16 pm Post subject: Re: JD 55 ABH plow |
Plow looks great! Nice job of painting it! |
Back to top |
DeltaRed Tractor Guru
Posted: Sun Nov 19, 2023 3:32 pm Post subject: Re: JD 55 ABH plow |
Can you pin or otherwise secure it from comming unhooked?Maybe change hitch type? Use a safety chain to catch it if it does come unhooked.Can the tail wheel be secured? |
Back to top |
Posted: Sun Nov 19, 2023 4:09 pm Post subject: Re: JD 55 ABH plow |
Back to top |
Posted: Sun Nov 19, 2023 4:16 pm Post subject: Re: JD 55 ABH plow |
Sorry Delta, I hit the wrong button uploading pictures. Anyway, this is the hitch on the plow. We are not sure if it is the correct one or not, but it has been on here for a while apparently. Grayson used this plow for the 2023 growing season after he had cleaned it up and I painted it for him. I could never find a pin hole to lock the tail wheel straight, nor find a good way to makeshift tie it still in a straight line. |
Back to top |
Posted: Sun Nov 19, 2023 4:19 pm Post subject: Re: JD 55 ABH plow |
Thank you. I'm definitely not a
professional painter ! I did hate to see
him go to the field with it last year
after we had finished it though. |
Back to top |
rustred Tractor Guru
Posted: Sun Nov 19, 2023 4:23 pm Post subject: Re: JD 55 ABH plow |
there is a pin for the furrow wheel to hold it straight when it transport. that hitch dont look right something wrong there. betetr check that hitch setup. something not right. |
Back to top |
Posted: Sun Nov 19, 2023 4:24 pm Post subject: Re: JD 55 ABH plow |
If it's not too much trouble, would you happen to have a picture of how your plows are set up to accommodate pinning the tail wheel straight ? If nothing else, maybe I could engineer something likewise for this plow based from the picture. |
Back to top |
Plowman Regular
Posted: Sun Nov 19, 2023 4:28 pm Post subject: Re: JD 55 ABH plow |
HI That is a IH hitch not factory Deere hitch |
Back to top |
Posted: Sun Nov 19, 2023 4:43 pm Post subject: Re: JD 55 ABH plow |
post a pic of the rear tail wheel of the plow, cant see a thing from that picture. plus if your traveling more that 7 mph with it your going to fast to transport it. it will run all over the road. how far are u going? |
Back to top |
David from Kansas Tractor Expert
Posted: Sun Nov 19, 2023 5:44 pm Post subject: Re: JD 55 ABH plow |
The early 55ABH plows did not have that anti-swing/tail whip feature but it can be put on. I may have an extra one. Can send picture if you want. In the old days, we would take a piece of wood about 12-18 long and 1.5 square and drive it in the opening on the top of the tail wheel swivel. Email is open. |
Back to top |
Posted: Sun Nov 19, 2023 5:48 pm Post subject: Re: JD 55 ABH plow |
crsutton81
If you don't get a reply buy mid-morning Monday, I will get you a picture. email is open. |
Back to top |
Posted: Sun Nov 19, 2023 6:09 pm Post subject: Re: JD 55 ABH plow |
Here is the tail wheel assembly. The typical travel distance my son goes is approximately 3 miles one way to get to most of his fields. As far as speed, 4th gear maybe half throttle on a Farmall 300 is about the limit before any chaos begins. We have some paved roads in bad shape around here. A un graded dirt road rides better than asphalt paved roads. I would like for him to be able to go on down the road with it to limit his exposure to traffic. |
Back to top |
