8n Carb bowl trouble
cat236
PostPosted: Fri Aug 10, 2007 2:43 am    Post subject: 8n Carb bowl trouble Reply to specific post Reply with quote
I am not positive of the year I believe it to be a 52 8n. I have had for a couple of years and have been slowly rebuilding. Unit had set uncovered for many years before I got it and have repaired electrical and rebuilt distributor and changed to 12v system.Replaced radiator,waterpump and all hoses. Replaced fuel tank, sediment bowl assembly and installed a complete overhaul kit in carb.New float,valve needles gasket the works. I soaked in carb cleaner and used a torch tip cleaner to run through all jets and orifices and blew out with compressed air.Tractor will start and run but soon dies I know it is not keeping carb bowl filled with fuel. I have removed fuel cap to check tank vent.I installed a known good sediment assy.,replaced fuel supply line,removed and reinspected carb.If I watch sediment bowl it will fill but after it runs and dies or you drain it it takes a very long time to vent and allow it to fill again.Which of the passages in the carb are vent ports? Thank you in advance for any and all of your help.
Dell (WA)
PostPosted: Fri Aug 10, 2007 3:37 am    Post subject: Re: 8n Carb bowl trouble Reply to specific post Reply with quote
Cat........you write......."If I watch sediment bowl it will fill but after it runs and dies or you drain it it takes a very long time to vent and allow it to fill again.".......that is semi-normal. Your float valve needle is "sticking closed". Usually, there is a wire clippy from backside of the needle to the gravity operated float to pull the needle point OPEN. Not all float valves have the wire clippy, it is a "not to worry too much" kinda thing.
You write......."Tractor will start and run but soon dies I know it is not keeping carb bowl filled with fuel.".......this is usually a fuel valve assy problem, yer in-the-tank fill'em tubes are clogged. Maybe you can "back-blow" the gas line up from yer carb elbow filter joint. Also check yer carb elbow filter at the sametime. Don't OVERTIGHEN yer glass bowl thumbwheel.......Dell
Phil (NJ,Az,Sask)
PostPosted: Fri Aug 10, 2007 3:38 am    Post subject: Re: 8n Carb bowl trouble Reply to specific post Reply with quote
The Carb venting is sourced from the space around the Venturi. The Venturi should be installed with "Flat" flange down. The Input to the Venturi area is a large port in the AIR inlet (Filtered)after the choke. The upper half of the Carb has the bowl venting ports
I don't think your sediment bowl should be Empty, at any time, unless the Carb bowl is FULL & Needle Valve is closed. If you open the carb drain the Sediment bowl should immediately fill & stay filled.
You may have a float that is hanging UP or the Needle valve is Sticking.
JMHO
Ken Crisman
PostPosted: Fri Aug 10, 2007 3:51 am    Post subject: Re: 8n Carb bowl trouble Reply to specific post Reply with quote
If it was me , I'd get an empty can or jar & hose . Set the can on floor ; unhook line to carb & slip the hose over the end of line & see if gas flows a good stream by letting it run into a can for a few seconds . Also check for debri from the tank .If it does good, then its your needle valve /float not working properly . When I rebuilt my carb I had trouble with the float rubbing against the ruffness in the bowl casting . Check the filters also . HTH ! Post back results & good luck . God bless, Ken
Phil (NJ,Az,Sask)
PostPosted: Fri Aug 10, 2007 4:06 am    Post subject: Re: 8n Carb bowl trouble Reply to specific post Reply with quote
BTW
The Venturi fits metal to metal, it is inserted into the gasket hole and then gasket is on the top of the bottom half. A damaged venturi that is not sealing Atmospheric air (Vent) from vacuum will cause problems.
RP-40-9n
PostPosted: Fri Aug 10, 2007 8:02 am    Post subject: Re: 8n Carb bowl trouble Reply to specific post Reply with quote
i think you have a sediment bowl problem, i have bought 2 new ones, had to take both back and repair the old one. pull the fuel line loose at carb and see if you have good flow at that point, if not then the cut-off valve is the trouble since you have a new gas tank, it should not be a dirt problem. RP
cat236
PostPosted: Fri Aug 10, 2007 12:00 pm    Post subject: Re: 8n Carb bowl trouble Reply to specific post Reply with quote
RP-40-9N,In fact I did what you said this afternoon,after viewing the responses posted.When I remove the line from carb,it will in fact run fuel out without any stopping.However I am unable to repair the initial sediment bowl as it,as well as the tank were damaged by corrosion beyond repair.As you stated the entire fuel system up to the carb are all brand new.This is also the second sediment assy I have tried as I suspected this to be the problem.I am unclear as to how to resolve this problem I have tried two seperate suppliers of sediment assy's as well.With about 50.00 in sediment assys I would like to resolve.Thanks to all how have replied.
Jerry/MT
PostPosted: Fri Aug 10, 2007 1:50 pm    Post subject: Re: 8n Carb bowl trouble Reply to specific post Reply with quote
If you have M-S carb, the fuel bowl vent is in the inlet passage as it is on all pressure balanced carbs. If you split the carb, you'll see asquarish hole over the air inlet sectiion. There are a couple of cast holes in the upper half that are over the fuel bowl. If you do an archive search, someone last year pulled colored wires through the M-S carb and showed the bowl vent system passages.
A quick check for flow restriction is to hold a container uner the carb and with the the tank valve wide open, remove the bowl drain. Gas should gush out continuously like a cow peein' on a flat rock! If it doesn't, ifit's intermittent, or just dribbles, then the fuel delivery is restricted.
Does your sediment bowl have a screen on it? If it does it maybe clogged. Have you pulled the fuel inlet elbow to the carb and checked the screen in there for clogging. Finally, have you checked your float setting? it maybe off and restricting the flow.
bcPA
PostPosted: Fri Aug 10, 2007 6:45 pm    Post subject: Re: 8n Carb bowl trouble Reply to specific post Reply with quote
I would put the patient on a IV. When I rebuilt my 8n and was not ready to replace the hood and gas tank what I did was use a used IV bag and clear hoses that my father insisted I take home from the hospital when he was a patient. Mom had a fit but he insisted. He said he paid for it and it was his and it was going home and not to be wasted and thrown out with the garbage. It worked perfectly as a temp gravity fuel source. With a similar set up you could comfirm or rule out a fuel line to tank problem.
cat236
PostPosted: Sat Aug 11, 2007 7:36 am    Post subject: Re: 8n Carb bowl trouble Reply to specific post Reply with quote
Thank you to all who helped out. I have it fixed a good friend brought a used sediment bowl and transfered some of the new parts to this one and installed. Runs great. thanks again.
